Remington Premier Rescue Knife 19848 Escape Made in Italy. 1974
Zombie Apprentice Posts: 10,549 Man of Multiple MultiTool Manufacturers
« on: April 16, 2018, 03:18:38 AM »
This is my first post in this sub-forum, so please forgive any terminology that is not correct in regards to rescue knives.
I found this at the store I work at today and paid $50. Seemed like a good deal at the time considering this isn't the Chinese Remington stuff here. This one is made in Italy. According to Remington's site, this was a small run item for several years and is discontinued now. The single blade versions can still be found around the interwebs for about $100.
This version is the model #19848 "Premier Rescue Escape".
Specs are as follows:
Handle length = 5.4" long
Handle thickness = 0.85" thick
Handle width = 1.53" wide (back to front)
Blade length = 3.75" long
Serrated portion = 1.2" concave shape
Plain edge portion = 2.5"  sheepsfoot shape
Strap cutter length = 3.3" in length
Inside sharp edge = 2.3" usable
Weight 8.42oz
The handle scales are nicely textured with a fairly comfortable grip when holding it tightly for its' size. The only sort of cheap looking thing about this knife is the grip-tape like white inserts, but I get this would assist in locating the tool in brush or debris.
The knife has two layers. One has the blade with a classic liner lock that works very well with the lock bar stopping at 50%. The other layer has the strap cutter. It is fully auto spring-loaded and uses a small button on the blade side to deploy/unlock. There is a sliding lock switch recessed next to it for safety. This functions well too.
At the butt end of the knife is a heavy-duty glass breaker that is incorporated nicely into the handle.
The sheath is outstanding and extremely well made. Looks to be made to mil-spec and is molle compatible. Heavy duty ballistic nylon construction. It can be worn vertically on any size belt and worn horizontally on a thinner belt. The closure is velcro and seems to be decent quality. The knife rides a tiny bit high when inserted into the sheath, but I am sure if you need a tool like this, a little weight isn't a big deal. This is only due to the fact the sheath doesn't seem to have been made quite long enough.
Pics. :tu:
* 20180415_193356-1.jpeg (Filesize: 80.55 KB)
* 20180415_193421-1.jpeg (Filesize: 66 KB)
* 20180415_193457-1.jpeg (Filesize: 116.69 KB)
* 20180415_193541-1.jpeg (Filesize: 186.11 KB)
« Last Edit: April 16, 2018, 03:24:47 AM by gerleatherberman »
Re: Remington Premier Rescue Knife 19848 Escape Made in Italy.
« Reply #1 on: April 16, 2018, 03:19:37 AM »
Pics 2/3.
* 20180415_193617-1.jpg (Filesize: 365.71 KB)
* 20180415_193637-1.jpeg (Filesize: 36.3 KB)
* 20180415_193705-1.jpeg (Filesize: 52.96 KB)
* 20180415_193721-1.jpeg (Filesize: 36.88 KB)
« Reply #2 on: April 16, 2018, 03:20:10 AM »
Pics 3/3
* 20180415_193742-1.jpeg (Filesize: 89.45 KB)
* 20180415_193750-1.jpeg (Filesize: 97.45 KB)
Thread Killer 2017 Absolutely No Life Club Posts: 9,248 Born to multitask.
« Reply #3 on: April 16, 2018, 03:15:30 PM »
That's so awesome!  :like:
I found a Remington rescue knife from an Australian seller. It had only the main blade, just like this one. No hook blade though. The seller would not send it, so, bummer.
« Reply #4 on: April 16, 2018, 03:58:39 PM »
Thank you, RP! :cheers:
That is so lame the seller wouldn't send it. Maybe you'll run across one again at some point! It is definitely a sweet looking main blade and built like a tank. :)
Absolutely No Life Club Posts: 5,197
« Reply #5 on: April 16, 2018, 07:15:34 PM »
I have had the $40 non-auto, one-blade version (can't carry an auto in Virginia) on my eBay watch list for a few months, which is $40. I like how the serrations are completely separated from the non-serrated portion--makes sharpening easier.
That looks like a great knife for anyone in the emergency services or even as a large EDC blade.
By the way, I think I might have found the reason for your sheath dilemma--the seller of the single blade mentioned that there was a smaller version--perhaps that's what the sheath was designed for and they didn't bother slightly enlarging it for the bigger blades.
« Reply #6 on: April 16, 2018, 10:47:34 PM »
Thank you for the info, cody! I would bet that is the case! The sheath would likely stretch open some with extended use, but that is a big oversight for a first responder tool. :ahhh
The blade is appealing in that regard for sure. And, I must add, this is absolutely the sharpest knife out of the box I have ever gotten. The serrations glide through phonebook paper.  :)
January Goal: $300.00
Due Date: Jan 31
Total Receipts: $152.47
PayPal Fees: $9.67
Net Balance: $142.80
Below Goal: $157.20
January Donations
SMF 2.0.18 | SMF © 2020, Simple Machines
Page created in 0.065 seconds with 55 queries.
© 2018 Defender Web & Tool
