My new Sportsman's nail file scratches blade is this normal?
00 Offline undertaker99
I thought the nail file would be better than the small blade because it works on small phillips but if it scratches the blade I should have gotten the tinker small
* Capture.jpg (Filesize: 20.05 KB)
us Offline NutSAK
Re: My new Sportsman's nail file scratches blade is this normal?
Reply #1 on: November 13, 2018, 12:04:56 AM
That's pretty normal. I see that on all 84mm Victorinox SAKs with the nailfile--cellidor and ALOX.  When deploying the nailfile, try not to put any more lateral force than necessary against the tool (toward the blade).  This will reduce the amount of contact.
- Terry
us Offline smiller43147
Reply #2 on: November 13, 2018, 01:47:55 AM
It's a little annoying but not really harmful.  That's why Wenger reversed the file.
Look at the Evolution 10.
- Steve
us Offline El Corkscrew
Reply #3 on: November 13, 2018, 05:52:44 AM
Is it one of the new nail files where the knurling goes all the way to the edge?
nz Offline Sawl Goodman
  • Between this & that.
Reply #4 on: November 13, 2018, 08:01:08 AM
I noticed the same thing with my Sportsman, with the old file. It seems to be because the file doesn't have the angled grind and thinness of the small blade to prevent it touching the main blade.
On my knife, the edge/lip of the file scratches against the blade, not the rough surface, which is lower than the flat lip surrounding it. I doubt that having the file facing out would make a difference.
It's a design flaw but hey, a few fine scratches on a blade are a tiny price to pay for having such a great knife. Keep enjoying it! :cheers:
I'd like to know too, just for knowing's sake. :P
I haven't seen an Evolution 10. I do have a Traveller with the file facing in. The tip just touches the blade when I open it. I can't say if it's caused any scratches because the blade has fine scratches on both sides. Unlike on the Sportsman there's a significant gap between the blade and file when they're closed. The file is somewhat thinner than the Sportsman's.
Rambler
Reply #5 on: November 13, 2018, 12:19:18 PM
Maybe it's a little inconvenient, but you can open the main balde before deploying the nail file. That would reduce the friction, I think.
 :think: :think:
The tip of my Compact's combo tool awlso hits the back of the blade. I just push it slightly out when closing it.
pt Offline MacGyver
Reply #6 on: November 13, 2018, 12:45:52 PM
That's unfortunately pretty normal, and also one of the reasons i don't like regular nail files on 84/91mm saks. All the tools there will rub n the main blade eventually leaving sime micro scratches like a sort of "rash" there, but that doesn't bother me. Now the darn file will scratch/ding the blade deep, especially the top of it.
As for the supposed Phillips utility of the tip, i find it very limited, cause other than very light torque will twist/bend the tip.
The four SD plate from the Swiss card is way better for that. I carry one on my key ring  :tu:
