Adding Scissors to a Soldier or SI
Myron · 11 · 1189
us Offline Myron
on: November 30, 2018, 11:39:12 PM
So I'm still a modding rookie, and I had this idea to add scissors to a Soldier/SI and make a Soldier X, or maybe even modify it further to be a 93 mm Voyageur-alike.
I understand from other threads that the scissors on a Pioneer X are identical to those used on 91 mm cellidor-scaled SAKs.  I have lots of 91 mm donor SAKs, so no problem there.   But obviously the backspring would not be the same going from a 91 mm setup to a 93 mm setup.
Is there another spring that will work?  I seek the wisdom and guidance of more experienced modders.
Thanks!
Myron
Re: Adding Scissors to a Soldier or SI
Reply #1 on: December 01, 2018, 01:23:24 AM
I'm no expert but I think the easiest way to go would be to use a Pioneer X as a donor.
Reply #2 on: December 01, 2018, 01:39:14 AM
Get the silver PX and grind off the keyring nub and you would have a Soldier X :think: :D
us Offline Myron
Reply #3 on: December 01, 2018, 02:35:42 AM
Thanks guys.
So if you wanted to make a 93 mm Voyageur-alike using a Vx Soldier or Wenger S.I. as a base, you could start with a Pioneer X for sure.    For the combo opener tool, could I use one from a 91 mm SAK?  Would it fit the 93 mm frame without looking weird, etc.?
Thanks,
Myron
Reply #4 on: December 01, 2018, 03:04:27 AM
Perhaps a much more experienced SAK modder than me can answer this questions much more eloquently than me :whistle: :D
Reply #5 on: December 01, 2018, 11:17:34 AM
You’ll have to drill the pivot hole to 3mm, but I think the 91mm combo tool will fit in place of the awl. :)
us Offline Myron
Reply #6 on: December 01, 2018, 02:54:15 PM
Thank you Mr Pablo. Just what I wanted to know.  :)
us Offline Simyo
Reply #7 on: December 02, 2018, 03:46:57 AM
You can use a combotool from a 91mm and you just have to drill it out like previously stated for 3mm and use a pioneer x for scissors that was also mentioned.  And you’ll have a voyageur.
us Offline Myron
Reply #8 on: December 02, 2018, 03:14:45 PM
Thanks Simyo!  Just what I was wondering.
Myron
id Offline jaya_man
Reply #9 on: December 06, 2018, 02:08:35 AM
Pioneer Solo backspring can work as scissors backspring with a little mod... I know someone shared it here in the forums but can’t remember exactly where...
us Offline Myron
Reply #10 on: December 09, 2018, 02:02:10 PM
Thanks Jaya.  I will search for the thread.  :)
