Next Naked Project
za Offline Max Stone
Re: Next Naked Project
Reply #30 on: September 26, 2019, 01:23:25 PM
Great work, Max  :like: These brass SAKs look really awesome!
Let me know once you take orders, I will surely want one  :D
PM sent...
Reply #31 on: September 26, 2019, 10:41:18 PM
Custom washers made up today from 0.05mm (2 thou’ inch) shim brass. To help with tool clearance.
Folded up a thin strip into about 10 layers and drilled a 2.5mm hole through the lot. Then mounted on a 2.5mm screw in my Dremel, sandwiched tight between 2 x 10mm diameter aluminum washers I made up earlier. Then spun down the brass shim on sandpaper until they matched the aluminum washer size. Job done.  :tu:
us Offline Myron
Reply #32 on: September 27, 2019, 07:22:30 PM
Very cool technique, Max.  I can't wait for mine!
us Offline Rapidray
Reply #33 on: September 27, 2019, 08:18:35 PM
Very nice job there! Excellent work  :cheers:
  :popcorn:
Reply #34 on: September 27, 2019, 08:38:14 PM
Thank you Rapidray and Myron!  :hatsoff:
Reply #35 on: September 29, 2019, 08:59:16 PM
Low Profile Naked Compact  :salute:
Reply #36 on: September 29, 2019, 09:30:16 PM
Very nice  :dd: :like: :like:
Reply #37 on: September 29, 2019, 10:13:48 PM
 :hatsoff:
us Offline jph_777
Reply #38 on: September 29, 2019, 10:32:40 PM
Max... Excellent work on the naked brass Compact!  It sounds as if you already have a ready market should you decide to start producing more of them.
Reply #39 on: September 29, 2019, 11:20:10 PM
Thank you jph_777  :hatsoff:
I’ve worked though the minor issues I picked up from the prototypes, so limited production has started. Above is first ready for a customer, Naked #1. It will have an identical twin, Naked #2  :tu:
us Offline Myron
Reply #40 on: September 30, 2019, 02:25:52 AM
Looks great, Max!
Reply #41 on: September 30, 2019, 06:38:05 AM
Thank you Myron :hatsoff:
Reply #42 on: September 30, 2019, 06:56:38 AM
Very cool job.
Reply #43 on: September 30, 2019, 06:57:35 AM
Thanks 🆘  :hatsoff:
Reply #44 on: September 30, 2019, 07:00:25 AM
This looks great, Max!
Reply #45 on: September 30, 2019, 07:01:05 AM
Thanks comis  :salute:
Reply #46 on: September 30, 2019, 03:45:56 PM
Still waiting for the naked part...
 :think: :whistle:
Reply #47 on: September 30, 2019, 03:46:51 PM
We have to keep it family friendly pfrsantos  :pok: :D
Reply #48 on: September 30, 2019, 04:26:58 PM
Would this qualify?   :pok:
Reply #49 on: September 30, 2019, 04:27:53 PM
Looking good Max  :like: :tu:
Reply #50 on: October 02, 2019, 06:13:36 PM
Well, I can see the pointy bits, so I think it does...
 :whistle:
 :D :D :D :D
us Offline Rapidray
Reply #51 on: October 02, 2019, 06:40:48 PM
Nice  :popcorn:
Reply #52 on: October 05, 2019, 07:54:36 PM
And then there were two...  :woohoo:
Reply #53 on: October 05, 2019, 07:55:21 PM
Very nice Max excellent work  :like: :tu:
Reply #54 on: October 05, 2019, 08:23:42 PM
Thank you Wim.  :hatsoff:
And on the peening. The trick is to start with a domed shape on the pin, and to have a small countersink in the scale. Then just careful, repetitive taps with a good quality light jewelry peening hammer. Must be mirror smooth on the face.
I start with the flatter side to swell the head and lock it into the hole. Regular inspections under a magnifying ring light to check I’m even all around. Once I can see the head has locked (no more gap around the pin/hole interface), I switch to the ball side and focus on rounding the edges.
The trick is go far enough to the edge to get it curved, but not too far that you strike the scale. The odd small tap does wander, but these miss hits are very difficult to see.
The pic below shows the amount of exposed rod I use to peen closed, about 1.2mm. I then remove the rod and shape/sand it to a dome to peen. Rod must be a good fit in the scale, no wobble, or you’ll need to peen a bigger head.
Next pic shows the pins ready before peening one side. Last pic is peened head (done in a vice, sandwiched in hardboard), inserted into bottom scale before assembly of SAK.
This has all been trial and error. But I’m happy with the results.
« Last Edit: October 05, 2019, 09:06:05 PM by Max Stone »
Reply #55 on: October 05, 2019, 08:58:48 PM
Excellent thanks for the explanation Max  :like: :tu:
Reply #56 on: October 05, 2019, 10:28:49 PM
BTW Wim...what’s with the bananas replacing the nuts?  :dunno:
Reply #57 on: October 05, 2019, 11:06:06 PM
I am no longer nuts I am now just bananas  :D
I made 60K posts yesterday  :tu:
Reply #58 on: October 05, 2019, 11:55:10 PM
That’s now really something to celebrate Wim!  :cheers:
What comes after bananas?  :facepalm:
it Offline SirVicaLot
Reply #59 on: October 06, 2019, 02:40:23 AM
Donkey Kong with Bananas, Nukes, the Yeti,....who knows. Speedy will find out in like two weeks  :D
