What to do about rusty Cadillac?
us Offline FolderBeholder
on: September 17, 2019, 11:15:39 PM
I have a Victorinox Cadillac that has a rusting/corroding St. Christopher shield.
I don't know if I should leave it as it is, or try to do something to stop the corrosion?
Ideas?  Thank you.
Up close:
us Offline Rapidray
Re: What to do about rusty Cadillac?
Reply #1 on: September 17, 2019, 11:17:28 PM
Tagging  :popcorn:
ca Offline Greg Jones
Reply #2 on: September 18, 2019, 12:12:04 AM
That's really nice, and I'm always shy giving advice that could be harmful, but I've had great success with toothpaste on items with light tarnishing
Reply #3 on: September 18, 2019, 12:12:42 AM
Well I had some Flitz that is apparently safe for plastic, so I rubbed a little in the metal and then rubbed it gently off with a microfiber cloth.
The results of the first try.
Reply #4 on: September 18, 2019, 12:14:15 AM
WOW!  :hatsoff:
Reply #5 on: September 18, 2019, 12:18:58 AM
WOW!  :hatsoff:
I like your toothpaste idea, but I think this Flitz did pretty good for a first try, I just don't want to damage the scales.
us Offline VICMAN
Reply #6 on: September 18, 2019, 12:29:59 AM
Very cool SAK FB! :like: :tu: :tu:
us Offline jazzbass
Reply #7 on: September 18, 2019, 12:48:28 AM
Pretty sure this is the breakdown of the cheaper CAB plastic of the Elinox knives from the 60s (yeah, I know the Cadillac is a Victoria knife, but they use the same scales as the Elinox Motorist. This is exactly the thing I was talking about in the Scales thread. The corrosion on the inlay is from acetic acid coming out of the scales. THis looks fairly mild, but the acid WILL etch away the aluminum liners and corrode the nickel silver inlays.
First step is to neutralize the acid. I like to use a baking soda paste or submerge in a baking soda solution. Luke warm water at most - the reaction speeds up with heat and UV according to what I've read. I do know for sure that cleaning some knives in a hot (120-130 F) ultrasonic bath has triggered a reaction that led to complete scale destruction in about 5 years.
Next, keep this is a place where it can breath and the acetic acid can dissipate. You don't want it in a sealed container alone and most definitely not with other knives - the acid will attack them as well. Most recommendations are to keep these knives away from heat, humidity, and UV.
Reply #8 on: September 18, 2019, 03:15:46 AM
Thank you JB, I will try some baking soda paste.  :cheers:
