Hi Myron. I’ve only found 2.0mm and 2.5mm hex-head bolts. And only plated steel. I played around a little with these and was not happy. 2.5m OK for 91mm pivots, but 2.0mm too small for inner pins, and tension was sloppy. Also, I found that even just nipping the nuts beyond finger tight would bind the tools, and even if I used threadlock, I’d still have to glue the scales on. So all-in-all I abandoned this and went back to brass and peening...
With 84mm, all the pins are 2.2mm, so I think you might have challenges finding suitable bolts. And resizing is a true PIA just for one tool.
Others have good success with bolts, but they seem to stick to 2.5 or even 3mm Alox for this.
(Edit: also bolt thread is not as smooth as the brass rod as a pivot.)
« Last Edit: September 20, 2019, 10:45:13 AM by Max Stone »
