The Amazing and Versatile, Yet Simple Toothpick
us Offline DIAMOND
  • Sometimes I sits and thinks, sometimes I just sits
on: February 15, 2020, 06:59:04 PM
Have you ever gone to tighten a screw only to find out the hole in the wood is stripped out?
Solution: Toothpicks! Insert a toothpick into the hole.
Once it reaches the end of the hole, break the toothpick off and reinsert as many as needed to fill the void.
No need to over-stuff the area. Just enough to fit tightly next to each other.
Wrong...
Right...
Now, turn in the screw. Ta-da!
Wooden stick matches will work for this too, as will wooden chopsticks. I've even shaved thick sliver off a 2x4 or other misc piece of wood laying around.
But I'm suggesting the unpretentious toothpick...because I get a merit badge.  :woohoo:
Thanks,
DIAMOND
MTs: Gerber Dime, Gerber Suspension NXT, PLeatherman Wave, Misc China Cheapos
SAKs: Vic Climber, Vic Classic SD, Vic Classic (non-SD), Engraved 3-blade SAK (given to me as a gift)
us Offline smiller43147
Re: The Amazing and Versatile, Yet Simple Toothpick
Reply #1 on: February 15, 2020, 07:04:59 PM
An old handyman's trick that I've used more than a few times.  Don't usually need more than one toothpick per hole, just enough so the screw bites again.
- Steve
us Offline DIAMOND
Reply #2 on: February 15, 2020, 07:07:52 PM
Reply #3 on: February 15, 2020, 07:35:05 PM
I thought that’s what the golf tee was for?
But good idea with the toothpicks!
us Offline DIAMOND
Reply #4 on: February 15, 2020, 08:28:33 PM
Certainly not for golf...at least not in my life.
Reply #5 on: February 15, 2020, 08:51:43 PM
I haven’t swung a iron in over 20yrs, but here,,
us Offline DIAMOND
Reply #6 on: February 15, 2020, 08:55:57 PM
Hinge
That's probably the number one area I've used this technique.
« Last Edit: February 15, 2020, 11:20:40 PM by DIAMOND »
Reply #7 on: February 15, 2020, 09:13:49 PM
I've also found golf tees ideal for plugging vacuum lines when working on cars.
- Steve
Reply #8 on: February 15, 2020, 09:14:12 PM
The holes gotta be the perfect size,,
Reply #9 on: February 16, 2020, 12:04:27 AM
Yeah broken pic links aside, the badge is for SAK toothpicks.
us Offline DIAMOND
Reply #10 on: February 16, 2020, 12:49:56 AM
Showing up fine on my end, both on laptop and on phone.
BUT, I tried it in IE and the links are broken.
Quote
Suggested Edit...
Start a new thread with a photo showing the SAK Toothpick being used in an unusual way.
But it's OK. I had more fun that any should creating a post on wood toothpicks.  :woohoo:
« Last Edit: February 16, 2020, 12:58:03 AM by DIAMOND »
Total Receipts: $0.00
PayPal Fees: $0.00
Net Balance: $0.00
Below Goal: $300.00
 0%
