84mm Scissors Question
on: June 02, 2020, 03:11:05 AM
I am thinking about building my own 84mm with scissors using a Cadet or a Bantam, since I already have a spare pair of 84mm scissors (sent back with repaired 84mm Craftsman). But, the scissors have a crude repair (missing screw replaced with brass pin--and I'm betting that crude repair resulted in stripped screw threads, so they might be unfixable; thus why Victorinox replaced them entirely on my Craftsman) and the spring is missing as well.  And, obviously, I don't have a backspring.
What can these scissors ride on, since I don't have an 84mm scissors spring? Taking apart an 84mm with scissors in it already is far out of the question.
au Offline PTRSAK
Re: 84mm Scissors Question
Reply #1 on: June 02, 2020, 03:24:53 AM
You can use a blade spring and make a perch for the other end from the tang of a scrap blade.
Have a look on the sticky tutorial thread at the "Wenger scissors and saw into 84mm" thread to see how it's done.
http://forum.multitool.org/index.php/topic,41486.0.html
au Offline Jspiggle
Reply #2 on: June 02, 2020, 03:26:37 AM
Also check out Syphs thread "How to build a modern golfer (84mm cellidor)"
id Offline jaya_man
Reply #3 on: June 12, 2020, 01:26:58 PM
+1 on what they said... I’ve done it the way Syph did... with a little modification to the process... That way I only sacrificed 1 scissor spring...
Reply #4 on: June 12, 2020, 01:44:03 PM
Look at that guy nibbling on that backspring :facepalm:
id Offline jaya_man
Reply #5 on: June 12, 2020, 01:46:08 PM
