Hi Comis,Many thanks for taking the time to respond and your suggestions.Yes, I’ll be starting with a Ranger. Another thought I have is to place the liner profiled for the saw on the scale side as you suggest and make two new scale liners from 0.5mm copper or brass sheet to keep the width down and match the lining of the two scales.Never made scales before, but I have tin snippers, a saw, files and a drill, so I can give it a go.My total output so far is a Yeoman and slim Huntsman.Thanks againSent from my iPad using Tapatalk
I'm thinking that just like a Compact is a slim ClimberA slim Huntsman is a Compact plus saw ?
That’s right, but I started with an existing Huntsman rather than a Compact. Removed the opener layer from the Huntsman and replaced the small blade with the Combo tool from an inexpensive Adler donor knife. Compacts can get pretty expensive in the U.K. As I didn’t start with a Compact it doesn’t have the pen or nail file on the back of the hook.Tried to cut two scale liners today from 0.9mm brass plate and a little Dremel electric hobby scroll saw. Made a bloody mess of it and a pile of discarded, snapped, expensive, Dremel blades. Maybe I’d do better with tin snippers and a file. Having spent years at a desk behind a laptop producing Excel, Word and PowerPoint perhaps I’m not cut out for this. Unfortunately a city dweller so no space for a proper workshop.Sent from my iPad using Tapatalk
But I do recommend always wear eye protection with high speed tools, one cannot be too careful with electric tools.
Tried to cut two scale liners today from 0.9mm brass plate and a little Dremel electric hobby scroll saw. Made a bloody mess of it and a pile of discarded, snapped, expensive, Dremel blades. Maybe I’d do better with tin snippers and a file. Sent from my iPad using Tapatalk
My first attempt at liners. 0.9mm brass. I'm not sure whether I will use them, I've ordered some 0.7mm sheet to have another go or might even stick with the original aluminium.Couple of Qs:1. Should I glue or tape the four together and then drill the pivot holes?2. Some filing is still needed, should I wait until the knife has been assembled and before the scales are put on?Regards,(Image removed from quote.)
I’m considering a three layer mod:1. Wood saw and micro screwdriver back tool2. Metal file and chisel back tool3. Main blade, Combo tool and Phillips back toolI’m new to modding so I am after a bit of advice. Is it okay to have the wood saw adjacent to a complete scale liner? Is there sufficient clearance provided by the shapes in the scale liner, or is the risk of rubbing too high? Is the saw normally sandwiched between cut cut down liners for that very reason?Maybe a dumb question, but I won’t find out unless I ask. I don’t want to go down this route if it is a non-starter.Thanks for any advice.
I had another attempt at making liners, both brass and copper.This time, I sandwiched the metal sheet between two sheets of thin ply before drilling the pivot holes and cutting out the shapes.Better, but still not good enough. The pivot hole centres are out by fractions but it still makes a big difference. Absolute precision is needed. I just don’t have the right tools to hold, drill and cut the work.I’ll give up for now. Wish liners could be bought.Sent from my iPad using Tapatalk
Just out of curiosity, did you use a center punch to help with drilling? Maybe that would help prevent the bits skidding?
