Can anyone confirm type and age of this SAK I just picked up?
gb Offline Grunthos
I managed to pick this up on the Interweb - more out of curiousity than anything else - I wanted a SAK with a fish on it!.
I suspect the knife is maybe a bit older than I originally thought.
Four layers, weight 100grams, metal inlay fish.
No sewing eye in reamer, keyring split ring missing, grooves in corkscrew, scissors with screw as a pivot (so <1991?), a silver tipped toothpick - first one I've ever seen (so <1978?). Thought the spring on scissors was broken but on closer inspection do believe it's a single leaf type spring (<1975?).
No hook. No metal/file saw.
Not sure if the tip of corkscrew, which seems bent forward, is an old "design feature" or a previous owner mod or wear and tear.
Overall she's in pretty good condition, hopefully just needs a bit of soap and water and an oil massage.
I'm guesstimating (using the marvellous SAKWiki) it's a pre-1975 original version Angler?
Can anyone confirm make and model and maybe narrow down the age a bit further?
Think I've just bought my oldest SAK (beats my trusty Champion "c" I bought 37 years ago). 8)
« Last Edit: February 03, 2021, 05:10:13 PM by Grunthos »
us Offline jazzbass
Re: Can anyone confirm type and age of this SAK I just picked up?
Reply #1 on: February 03, 2021, 06:44:48 PM
Correct, so this would put it pre-1986
Agreed
I hesitate to use tweezers as dating references since they're so easily swapped, but for knives like this it's a good indicator.
I think your first instinct was correct here. That is almost certainly a broken double leaf spring. A true single leaf spring will turn up towards the scissor pivot at the end, while yours turns down. Additionally, it looks like this is a model with the larger 1.9mm spring attachment and non-peened scissor screw, making it a 77+ variant.
Close - its an Original Angler from I'd say late 70s, c. 1977 or so based on the scissors and the inlays.
The inlays, BTW, are the most interesting part of this knife for me. It's hard to tell in pictures sometimes, but these inlays look like the early stainless steel versions. They appear to be white vs goldish for nickel-silver, but the fish icon is the older, more ornate "5 line tail" version from the nickel-silver era. Compare inlays:
The NS inlays were a lot more intricate with smaller lines and a LOT more detail (more scales, more lines, etc)  that apparently were harder on the press tooling and wore out the dies fairly quick. In fact, you can see what looks to be die wear on your knife where the bottom scales of the fish are gone:
Here's a great thread that talks about the early stainless inlays: https://forum.multitool.org/index.php/topic,82626.msg2001446.html#msg2001446
Cheers.
gb Offline Grunthos
Reply #2 on: February 03, 2021, 06:53:07 PM
Wow. A very detailed response. Many, many thanks (and some food for thought).
I'll take 1977, that year has many good memories for me!  :D
gb Offline Rizio Il Ghiro
Reply #3 on: February 03, 2021, 08:45:36 PM
Nice find, Grunthos!  :like: :like:
Reply #4 on: February 03, 2021, 09:46:21 PM
 :iagree: Very nice find.
JB, thank you.  I learn a lot from threads like this.  I appreciate the easy to understand straightforward approach for noobs like me.  I also appreciate the easy to digest detailed yet simple to understand info offered.  While I know dating SAKs can be very detailed the way you approach these threads is an a word, approachable.
 :hatsoff:
Off to look at my Fish scaled SAK  ;).
Reply #5 on: February 03, 2021, 10:06:11 PM
 :iagree: never knew there were so many fishy nuances!
Reply #6 on: February 03, 2021, 11:04:49 PM
Sorry if I'm high jacking your thread  :hatsoff:
Heres mine.  No half stops on openers.  Grooved corkscrew 4 turn.  NS Fish.
Reply #7 on: February 03, 2021, 11:05:21 PM
 :hatsoff:
Reply #8 on: February 03, 2021, 11:05:54 PM
 :hatsoff:
gb Offline Grunthos
Reply #9 on: February 03, 2021, 11:33:39 PM
You've not highjacked, you've added value!
 :hatsoff:
us Offline kamakiri
Reply #10 on: February 04, 2021, 12:29:45 AM
 :hatsoff:
Yeah, interesting!
Aloha’s looks ‘80/‘81...as weird as that may be.
Yours (Grunthos), is ‘77/‘78, and I think very early ‘78 despite the Aluminum tipped tweezers.
Reply #11 on: February 04, 2021, 12:33:08 AM
 :salute: Works for me and thank you kamakiri.  I picked it up cause I saw the fish and thought it was very neat.  I can see how inlays can lure us in  :facepalm:.
us Offline kamakiri
Reply #12 on: February 04, 2021, 01:53:41 AM
 :cheers: and agreed. I got lured in by the inlays. Thanks to you both for sharing. Interesting to see both of these inlays toward the ends of their use. I see some wear of the tooling in yours too (Aloha).
Reply #13 on: February 04, 2021, 01:56:40 AM
Now that you mention it I can too.  The details are much appreciated by you.  Jazz references your thread but its admittedly pro level info although very interesting.  Thanks to you both.   :hatsoff:
us Offline Jim the Brave
  • Hardwood sawyer, and follower of Jesus Christ
Reply #14 on: February 04, 2021, 05:13:12 AM
Yeah 1977 was my beginning...I was born in December of it.
This life is merely a staging ground for eternity. Are you preparing for the rest of forever?
us Offline kamakiri
Reply #15 on: February 04, 2021, 08:13:30 AM
And I keep finding more!  It’s crazy.
Quote
  :cheers: Thanks for that, but that thread is just scratching the surface of how many changes can be used within just the ‘70s. I’ve lost count.
Reply #16 on: February 04, 2021, 05:57:27 PM
 :D :D :D :D
Reply #17 on: February 04, 2021, 06:05:04 PM
Offline Helvetica Bold
Reply #18 on: February 04, 2021, 07:25:45 PM
Great find Grunthos and some great information I this thread, thanks everyone.
gb Offline Grunthos
Reply #19 on: February 04, 2021, 08:19:21 PM
Attached are some further photos of the corkscrew. These show how distinct the "point" is on the tool.
Have to say I'm pretty pleased with that aspect. A little more utility than the normal corkscrew and (luck or design?) it still fits snuggly when in a parked position.
So curious I wrote to the seller asking if he has any history on how it got that way. He tells me it came with a job lot of fishing gear he bought before lockdown.
So...I guess..."we will never know"... :dd:
« Last Edit: February 04, 2021, 08:38:35 PM by Grunthos »
