So we're talking about a month without access to your stuff. I'd keep ALL the tools pictured (and then some). Perhaps a small tool box/bag?
I can tell you, from my last experience with making a move - What I used was a Pioneer X and a Leatherman Wave. What I could have done well with was a Leatherman Signal. I needed / used / could have used - Phillips and Flat drivers (both LM and Vic were needed), serrated sheepsfoot blade, and the pommel for light hammering. So where my carry fell short - a bit set and a tool with reach would have done me some good, and I forgot to keep kit with me (because it's on the shelf 99% of the time), and a pommel.
If it can't be both then I'd go with option #1... with PlierWrench instead and a Ranger (91mm).The Ranger adds a file and a saw.Good luck with your move
Thanks for your thoughts. I assume you used the serrated blade for straps, plastic wrapping and boxes?Can't take the Wave. OHO blade
I have become a fan of the SAK & Knipex pliers combination. It so much more versatile than a stand alone multitool. So, I’d go with choice #1. I’d probably go with a SwissChamp, though.
I dont understand how this makes sense on any level at all if you will need to move out of one place and in to another,I would make sure that had the tools I need to do this regardless of them fitting in a pocket or not. I am not at all sure that anyone has ever tried what you are proposing and lived through it even? This is the minimum that I could get by with......maybe. And a Cordless Driver and Bits too!(Image removed from quote.)(Image removed from quote.)
The Swisschamp covers all your bases. For pliers, I'm with Stitch. You can't beat a Plierrench!
right, right, and right on the serrated blade. Sounds like a job for a Vic Spirit
As much as I like the MP series, I'd go with option #1. Many times I need to hold a nut or another surface while unbolting/unscrewing, or hold on to a thin steel bar or something to cut and would not be able to if only had the Gerber. I find more practical (in a situation like yours) to keep the tools separate as in option #1. Besides, the grip on the Knypex is out-of-this-world, and having angled jaws can make furniture disassembly easier. Just my $0.02!, and good luck in your new venture.
Well if you put it that way i might need to hire someone to carry my tools wherever i go. And maybe one of those snap-on trucks. You know, just to be sure
There is a looooong way between that and what you are thinking of keeping and I would want to be able to take care of things that I might need to do before leaving and before moving in so if you cant carry a small Zip bag with real tools in it I think you might have other problems here honestly?I easily check these onto my luggage as I need to,thats why I built this.So I was only half kidding really,I would never think a few MT is enough for the possibility of real work being needed to be done.
You are right of course, i would prefer to have dedicated tools available as well. But with the way our travel is set up and restrictions in place, that just won't be doable. If I run into a situation that i really cannot handle with the tools I have, I will ask a neighbour to borrow some.
Something else to consider, if you find your MTs are not up to what you need at your destination, is to purchase one of those prepackaged tool sets when you get there. They start as inexpensively as about $20, and while quality sometimes isn't the greatest, choosing the right set will give you a usable basic selection of tools.
Thanks, gents Maybe I'll go with Knipex Plierwrench, Spirit XC and Vic bit wrench with bits. That gives me a lot of options
Please forgive me if this is stepping over the line, and please feel free to tell me to smurf off. If your stuff isn't going to show up for a month after you move, what are you sleeping on, how are you cooking and storing your food, etc? Are you buying new appliances and furniture after you arrive? Takeout for a month? Genuinely interested.
