I'd say... get a Walker.
What tools would you like to have? Knife, saw, combo tool and...? I see you mention the Hiker so I'm guessing backlayer tools too? Awl? Phillips? That would complicate things a bit as you need backsprings that the my First Vic and Walker lack, as the backlayer tools require different springs.
If you're looking for a 3 layer SAK anyway, then why not an Alox farmer like Kirkie suggested?
The Farmer is a great knife. I may look for one, especially if I can find a reasonably priced golden orange one. The thing is, I already own a Hiker, which is pretty comparable, and lighter. I took a look at the specs on the 3 layer 84mm models (like the Salesman) and they come in at about 70 grams. My Hiker is only 77 grams, so I doubt if I'd be saving enough weight to make it worth my time to even modify one. The Farmer is about 9 grams heavier than my Hiker.Here's my Hiker:(Image removed from quote.)
A couple of thoughts…You’ve mentioned a lot of uses of the awl and can opener, but no actual uses of the saw. If you would be willing to consider doing without the saw, that gets you down to a Tourist or Sportsman.Take a Farmer and remove the opener layer, leaving you with a slim 2-layer 93mm containing just the main blade, awl, and saw. Toss a P-38 in your kit or attach it to your key chain to cover can opening duties, and you’re good to go.As you may be aware, the corkscrew actually makes a pretty handy little marlin spike for things like bootlaces and paracord, or any other cordage that is smaller in diameter than the space between adjacent corkscrew turns.
So... how many grams matter to you then?
I was just looking for trying to go lighter than my Hiker if possible, and wanted to know if there were options.
Does anyone know what this knife is?(Image removed from quote.)
Bushcrafter I thinkhttps://www.sakwiki.com/tiki-index.php?page=Bushcrafter_SwissBianco
I’d say pick up a farmer and if it’s too bulky You’ll have all the parts you need to mod a bushcrafter Also welcome!
