Can I swap a scissors for the main blade in a VSAK Electrician?
Ike582 · 14 · 1589
us Offline Ike582
I really like the small sheepsfoot blade in the VSAK electrician, and have little use for the full size blade.  Is it possible to swap out the main blade for a scissors relatively easily?  I'd like to make a slim Electrician-X if possible.
Thanks,
Ike
Ike
Offline Berndstein
So, you want to replace the small blade with the electrician blade and the large blade with scissors?
Gesendet von meinem Pixel 5 mit Tapatalk
us Offline Ike582
My thought was to start with an Old Cross Electrician and just swap the large blade for a scissors, leaving everything else "as is".
Ike
I'm no expert, but scissors have their own spring. I never heard of anyone replacing a large blade with scissors. I think even the width and length of the scissors would conflict with the small blade/awl/combo tool.
 :think: :think:
gb Offline andywork
Hi Ike,
I don’t think it’s possible to only remove the main blade, to replace it with scissors.
I think the awl would have to go too as pfrsantos mentions.
Though, you could just add scissors like the lovely Brasswerx custom Electrician X. (See below)
The closest I’ve seen on this forum is this Pioneer X mod:
https://forum.multitool.org/index.php/topic,76301.msg2168301.html#msg2168301
You’d just need to replace the can opener, with the Electrician’s blade.
Hope that helps,
Andy :)
« Last Edit: August 19, 2021, 07:27:36 PM by andywork »
us Offline Ike582
Andy, that's very helpful, thanks.  Given that the can opener is for me the least used tool, swapping it out for an E-blade is a very attractive mod option for me.  Now I've got to figure out how to do it!
Ike
gb Offline andywork
… Now I've got to figure out how to do it!
Yeah, unfortunately that’s where I fall down too.
I’ve never found out how other people do all these wonderful mods so well? :think:
My one and only attempt has gone unfinished. And I don’t even know who to ask to commission a custom SAK for me?
Good luck. :tu:
us Offline Ike582
Thanks Andy!
Ike
gb Offline andywork
Thanks Andy!
No problem.  :tu:
And just in case you wondered what it would look like, in virtual reality...  :dd:
(Sorry, I didn't use an Old Cross)   :(
I really quite like it! :tu:
be Offline SMLE
us Offline Ike582
Re: Can I swap a scissors for the main blade in a VSAK Electrician?
Reply #10 on: August 28, 2021, 08:28:02 PM
SMLE, that’s fantastic!  You even used the OC scales which I prefer.  Did you do it yourself or have it made?
Ike
be Offline SMLE
Reply #11 on: August 28, 2021, 09:32:39 PM
SMLE, that%u2019s fantastic!  You even used the OC scales which I prefer.  Did you do it yourself or have it made?
It was made by https://www.w3rktrieb.com/ in Germany
Great knife blue titanium OC scales, it is a perfect knife, carries well with a lock blade.
« Last Edit: August 28, 2021, 09:49:26 PM by SMLE »
00 Offline Mechanickal
Reply #12 on: August 29, 2021, 10:40:28 AM
Brunner in Switzerland does amazing work too but uses Cerakoted alox scales instead of Ti.
In fact, Elsener himself has a few of his mods in his private collection.
us Offline Ike582
Reply #13 on: August 30, 2021, 07:40:45 AM
Thanks for the leads!
Ike
