Victorinox outrider mod
Offline arghles
on: October 14, 2021, 03:26:26 PM
Hello I want to add a layer at my outrider victorinox is it possible? Where can I find tools and the things that can serve?
Inviato dal mio SM-N970F utilizzando Tapatalk
us Offline kamakiri
Re: Victorinox outrider mod
Reply #1 on: October 15, 2021, 07:25:11 PM
Certainly possible. Just need to find the donor parts you want and to get the right pins for the new width. Pins needed are different for liner lock vs slide lock.
What are you trying to add?
Offline arghles
Reply #2 on: October 15, 2021, 07:38:22 PM
Hello I want to add pliers and a small blade, and at the other side a hook. G10 scales and if possible replace the pins with screws
fr Offline hulk.
Reply #3 on: October 19, 2021, 11:58:48 AM
hello
adding an existing layer does not involve any great difficulty.
but composed a hybrid with tools of different sizes of sak it is much more complex
here I believe it is impossible.
the pliers and one of the tools that has one of the thickest springs with no space for the back tools.
and there is not enough room to add a small blade in front.
 :dunno:
Offline arghles
Reply #4 on: October 19, 2021, 12:44:17 PM
 The problem is find the pliers
fr Offline hulk.
Reply #5 on: October 19, 2021, 02:41:15 PM
Skipper,Work Champ,Hercules,..
you just have to find a donor
the clamp and also identical on the 91mm, it just has the additional nail, which does not interfere with this particular case
Offline arghles
Reply #6 on: October 19, 2021, 04:17:21 PM
The other solution is to buy a workchamp and remove a layer
Inviato dal mio iPad utilizzando Tapatalk
fr Offline hulk.
Reply #7 on: October 20, 2021, 09:57:00 AM
yes  ;)
us Offline kamakiri
Reply #8 on: November 04, 2021, 07:04:05 AM
Actually, you can have all that, but you’d have to add another layer for the small blade. And it might as well have another tool on the opposite side.
The hook isn’t a problem. Just need all the right donor parts. And not behind the pliers.
us Offline kamakiri
Reply #9 on: November 06, 2021, 04:52:52 AM
An ‘outer’ spring just needs to be used in one of the inner layers with either a saw or the main blade.
Lots of options for the small blade with an added layer. I’d use an opener layer spring and both 91mm blades. Could also be the layer you’d add the hook to.
Mock-up of hook and wood saw:
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
