December Rebar Challenge
Adam5 · 873 · 21621
us Offline Adam5
Re: December Rebar Challenge
Reply #210 on: December 04, 2021, 07:01:26 PM
I made this mod more than a couple years ago and many probably got tired of seeing it when I first made it :whistle: :D but it has been a while since I have carried it and took many pics of it :cheers: It is a dual colors Rebar with a Kick clip mod, diamond file and scissors 8)
I am not tired of seeing it   :dd:
I am not a fan of all BO MTs, but I am a fan of dual color MTs  :2tu:
us Offline Adam5
Reply #211 on: December 04, 2021, 07:11:34 PM
Day 4
A recreation of how I was using my Rebar earlier today:
This is the #1 use I have for a SE blade. It cuts through the flexible conduit and its nylon reinforcement better than a PE blade does.
se Offline kottskrapa
Reply #212 on: December 04, 2021, 07:23:18 PM
Day 4 - not much rebar work today, I had a 12h shift today and one tomorrow but I did get to tight this valves handle when I got home. And nice pics everyone!
Reply #213 on: December 04, 2021, 07:33:41 PM
Thanks Adam  :hatsoff:
Great pics and uses Adam and kotts :like: :like:
bg Offline DavisNikolov
Reply #214 on: December 04, 2021, 09:23:37 PM
                                    Day 4
Used the Philips to tighten the handle of the saw. Needed to make one more chicken feeder because they were fighting too much over the first one.
Feeder inspected and approved
Since I was in the coop improvement mode already I made them a designer lampshade.
Later in the evening used the blade to open a pack of Christmas themed socks for the kid
se Offline RF52
Reply #215 on: December 04, 2021, 09:41:10 PM
Day 4:
Some pizza prep today :tu:
* 1638650352086.jpg (Filesize: 38.63 KB)
* 1638650352078.jpg (Filesize: 52.97 KB)
Reply #216 on: December 04, 2021, 10:04:15 PM
Day 04
* KIMG1737~2.jpg (Filesize: 276.92 KB)
Reply #217 on: December 04, 2021, 11:13:40 PM
Great use, Steve :like: what's in the package? :dd: :popcorn: :D
Just some wool socks   :D
Reply #218 on: December 04, 2021, 11:14:03 PM
bonus pic
* 20211204_125906.jpg (Filesize: 458.16 KB)
Reply #219 on: December 05, 2021, 01:12:17 AM
Awesome pics today :woohoo: :like: :like:
Was hoping for another old school LM but still not bad :D
us Offline Rich_SD
Reply #220 on: December 05, 2021, 01:18:49 AM
Lots of great reports on Rebar usage (especially Davis) and lots of nice pics!  I really like Steve and David's continued inclusion of traditional folders too  :tu:  And don't get me started on black oxide 🥰
Reply #221 on: December 05, 2021, 01:21:14 AM
Resistance is futile   :pok:
us Offline Rich_SD
Reply #222 on: December 05, 2021, 02:11:27 AM
Day 4
After 3 days of my Rebar riding low and horizontal in my pocket, I need to start working on a pocket clip solution.   Decisions, decisions...
Since it's the easiest to apply and remove, I'll start out with the suspension clip:
I've been carrying my Rebar all day with the suspension clip, and it works great.  The Rebar hangs in the perfect position, and I don't even notice it's there.  The PST did the same with the suspension clip, but the Rebar is just as comfortable, yet it is a much beefier tool.  All was going well until I needed the blade to open some packages and to cut off some labels...
Crap!   I would say that's less than ideal, especially since I use the blade so frequently.  I'll keep it this way for a few days, but I suspect I'll switch to the Nite Ize clip.
pr Offline Juan el Boricua
Reply #223 on: December 05, 2021, 02:33:24 AM
Ooops... Sorry it's not working for you Rich; had you tried dropping the lanyardring/clip back over the handle, like I do in first picture? The 2nd. picture is to show how it's clipped. Hope this helps (but if not, the Hip Clip is a great solution! :tu:)
* 20211204_212503.jpg (Filesize: 87.13 KB)
* 20211204_212433.jpg (Filesize: 86.21 KB)
us Offline Rich_SD
Reply #224 on: December 05, 2021, 02:40:21 AM
Thanks!  I'll try it that way tomorrow.  Just playing around with it in my hand (not actually cutting anything), I suspect that it will still flop around too much.  I wonder if I could use a small magnet to keep it secured away from the blade.
us Offline Rich_SD
Reply #225 on: December 05, 2021, 02:48:32 AM
Thanks, Rich :hatsoff: I didn't destroy the Kick ;) I just swapped the Rebar knurled screw into at after getting tapped the one from it :cheers:
I purchased the tool to remove those knurled screws, but I doubt my ability to do a swap like that.  It also looks like a decent amount of filing is required on the Rebar to make room for the side of the clip  :ahhh
Reply #226 on: December 05, 2021, 03:00:56 AM
This sounds like a good idea...
...the 2nd one highlighted, not; you could try taking the pivot out, study and then measure and try out the clip without the filing; get to know what's there. Then decide if or how much filing is needed and if willing. If not, it's just a matter of putting everything back toghether as it was.  :tu:
wales Offline GearedForwards
Reply #227 on: December 05, 2021, 03:10:16 AM
I thought the same thing and was going to show the same thing, well you may be significantly faster than me Juan, but I'm still doing it  :ahhh
Reply #228 on: December 05, 2021, 03:15:41 AM
Good to know that someone else has a similar way of thinking as I do!!  :cheers:
nz Offline Pauldmmwc
Reply #229 on: December 05, 2021, 03:16:50 AM
Hello day 4.
Fan replaced on the ice machine and now some reassembly required.
* rebar day 4.jpg (Filesize: 215.49 KB)
Semper Sitienti !!
Reply #230 on: December 05, 2021, 03:17:11 AM
Is this why I have a pile of PVC pipe?  :think:
Reply #231 on: December 05, 2021, 03:17:59 AM
Probably... :rofl: :rofl: :rofl:
Reply #232 on: December 05, 2021, 03:31:28 AM
Nope, no filing if you don't want to :D You can cut the notch but I was already using that clip as a wrench before I got the loki wrenches and had bent the clip flat :whistle: it swivels a little from time to time but sit well in the pocket without moving :salute:
ph Offline Zephon
Reply #233 on: December 05, 2021, 04:08:50 AM
Day 5
December 5
Nothing special for Sunday. Trying to get some rest and all that.
Reply #234 on: December 05, 2021, 09:12:16 AM
Day 5 - I'm at work until 18 tonight and I don't thing I will need my rebar that much
Reply #235 on: December 05, 2021, 01:31:43 PM
Day 5
* 20211205_082814_copy_859x645.jpg (Filesize: 490.81 KB)
us Offline Adam5
Reply #236 on: December 05, 2021, 04:05:37 PM
Day 5
Used the awl last night to punch a couple of holes in some straps for my wife:
Reply #237 on: December 05, 2021, 05:28:19 PM
Day 5 is off to a great start   :like: :tu:
* 20211205_101227.jpg (Filesize: 277.63 KB)
Reply #238 on: December 05, 2021, 07:22:17 PM
 :iagree: awesome pics :like: :like:
Reply #239 on: December 05, 2021, 07:23:26 PM
Day 5 of 30
The brother to yesterday's Rebar :cheers:
