Login
Register
Menu
Home
Help
Forum
Tool Talk
Swiss Army Knights Forum
Philips from the mini tool set
z1913
9 ·
1336
« previous
next »
Print
Pages:
1
Go Down
z1913
Hero Member
755
on:
December 07, 2021, 07:29:07 PM
Those of you who owns the mini tool set - is it possible to use the philips screwdriver (the size is described as 000) on the philips typically used on battery compartments, children toys etc? Or is it too tiny? Thanks for any hands on experience!
Merit Badges
Simon_Templar
No Life Club
1,440
Re: Philips from the mini tool set
Reply #1 on:
December 07, 2021, 08:53:03 PM
Frankly, no. You can poke stuff and show it off in the corkscrew of a SAK with green scales (that's what I do), but as a screwdriver it's really quite useless
Tasky
Hero Member
808
Galaxy-hopping garbage-man
Reply #2 on:
December 07, 2021, 09:07:08 PM
If it's really a PH-000, then most likely not.
Kids' toy battery compartments and the like are usually secured with screws sized for adult hands, so more the PH-0 size or larger.
I use PH-00 fairly often on electronic stuff, though less often the PH-000. The later is very small and most typically found in mobile phones, as well as watch mechanisms and jewellery.
Merit Badges
z1913
Hero Member
755
Reply #3 on:
December 07, 2021, 09:10:08 PM
Thanks!
Merit Badges
MacGyver
No Life Club
1,550
Reply #4 on:
December 07, 2021, 09:47:57 PM
My guess is the classic flat head mini SD will work better for those screws than this mini phillips. I toke off the back panels on my laptops for ram, HD, wifi, with the micro flat SD
Rizio Il Ghiro
No Life Club
4,263
Reply #5 on:
December 07, 2021, 11:18:56 PM
I’ve got a couple of these sets, mainly for the colours to be honest…. Well I’ve compared the mini crosshead it to my Wera and Wiha mini screwdriver bits and I think it’s more like a PH 000 than a PH 00. I’ve used it for tightening the rare cross head screws on spectacles with success, but I suspect it might be a bit on the small side for the screws you have in mind. Is it essential? Well, no, but then neither is having Wiha and Wera bits/screwdrivers that double up, but this MTO after all! When it comes to other screws, I use VOH flats on watches and JIS mini screwdrivers on Japanese cameras, though the Wera set was originally bought to look after German/European cameras (Rollei, Leica, Linhof)….. But buying tools isn’t really spending, is it?!?!
Merit Badges
cody6268
Absolutely No Life Club
6,230
Reply #6 on:
December 08, 2021, 03:15:56 AM
These, along with the super-tiny Torx are only useful in cellphone and tablet repair. And in my opinion, if you're gonna do that, you've gotta have the right tools.
Merit Badges
z1913
Hero Member
755
Reply #7 on:
December 08, 2021, 06:23:50 AM
Thank you all for the valuable input!
The reason I asked is that during contemplating (overthinking...) about my ususal set up (Rambler + Waiter) with the neverending quest of my minimalist mind to further simplify (but as Rizio rightfully stated above - it is MTO afterall!), I came to the idea that if I downgrade the Rambler to Alox Classic, I would reduce the redundancy of T+T and botttle opener covered by Waiter and get the super slimness and lighteness of alox classic for my keys but I would loose the very handy small philips on Rambler - which capability I would like to keep and the idea with mini philips added to Waiter came up as a solution.
But my doubts about the practicality of the 000 philips are confirmed by your hands-on experience...
So now I am thinking of replacing the micro driver on the mini tool with larger philips - similar to the one on Rambler. Maybe cut the the mini tool, extract the existing one, replace with something larger and epoxy everything together again?
Merit Badges
Farmer X
Zombie Apprentice
13,744
Master of the unexciting
Reply #8 on:
December 09, 2021, 12:08:06 AM
I did a quick test. My cats' laser pointer has its battery cover held on with a #0 Phillips. The screwdriver tip on a Classic SD struggled a bit due to tight confines, but I was able to turn the screw. Further testing would doubtless be needed, but the Classic SD seems to do just fine on a #0 Phillips.
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
April Goal:
$300.00
Due Date:
Apr 30
Total Receipts:
$42.16
PayPal Fees:
$2.92
Net Balance:
$39.24
Below Goal:
$260.76
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
