Login
Register
Menu
Home
Help
Forum
Tool Talk
Gerber Tools
Nxt Handle Splay
Nxt Handle Splay
tonyg
9 ·
1511
« previous
next »
Print
Pages:
1
Go Down
tonyg
Full Member
183
Nxt Handle Splay
on:
May 18, 2022, 08:50:40 PM
A few years back, someone mentioned reducing handle splay a on a Gerber NXT, but I didn't quite get how they did it. Anyone ever do this, and if so, would you mind explaining how and with a few pics? Thanks.......
NetsNJ
Hero Member
676
Re: Nxt Handle Splay
Reply #1 on:
May 18, 2022, 09:44:46 PM
You can file down the tabs that the plier head pushes against when open. Getting the plier head out is difficult though without stripping the screws.
tonyg
Full Member
183
Reply #2 on:
May 18, 2022, 11:03:57 PM
Doesn't sound like it's worth it..........thanks.
Juan el Boricua
No Life Club
3,753
Reply #3 on:
May 19, 2022, 03:13:30 AM
TonyG, don't give up that easily, maybe this will help? (And I did not took the pliers head off to make the modification) ...
https://forum.multitool.org/index.php/topic,48158.msg2058805.html#msg2058805
Good luck!
Merit Badges
tonyg
Full Member
183
Reply #4 on:
May 21, 2022, 04:42:15 PM
Thanks Juan.......your original post is what prompted this post. However, the way my brain functions, I'd do better with a pic or two. Could you possibly do that? Thanks very much.
Juan el Boricua
No Life Club
3,753
Reply #5 on:
May 28, 2022, 07:04:24 PM
Ok tonyg, here it is and, hope it helps; at the pliers stop, draw a .5-1.5mm line across it on both sides of the pliers (I'm using the one I did as an example; you can see where the original stop was ground; mines were 1mm). [ You are not allowed to view this attachment ]
Now, using your rotary tool, grind away up to the line you made. I first cut with the carbide tip and finished off with the stone. [ You are not allowed to view this attachment ] [ You are not allowed to view this attachment ]
Merit Badges
Juan el Boricua
No Life Club
3,753
Reply #6 on:
May 28, 2022, 07:06:40 PM
Merit Badges
Juan el Boricua
No Life Club
3,753
Reply #7 on:
May 28, 2022, 07:11:31 PM
Once satisfied with the work, clean with compressed air. If, like me, you don't like the shinyness, you can place a drop of muriatic acid/ hydrogen peroxide mixture (1:2) to the area until etched; clean with a dilution of baking soda, rinse with plain water, dry, and lube. You should end up with something like this middle one, as compared with MP600 on its left and, Wave on its right): [ You are not allowed to view this attachment ]
It will also open and close with a factory-like snap, and will not open by itself. [ You are not allowed to view this attachment ]
Last Edit: May 28, 2022, 07:58:13 PM by Juan el Boricua
Merit Badges
Juan el Boricua
No Life Club
3,753
Reply #8 on:
May 28, 2022, 07:15:39 PM
Here's a picture of the bit I used for cutting the stop: [ You are not allowed to view this attachment ]
And please, don't mind the knackered pivots, as it was used at one time as a parts tool donating its scissors, awl, and combo tool to other MP's (but it is now all back to itself!, and used around the house). Hope yours do fine, and to see pictures soon because...
Last Edit: May 28, 2022, 08:00:05 PM by Juan el Boricua
Merit Badges
Print
Pages:
1
Go Up
Forum
Tool Talk
Gerber Tools
Nxt Handle Splay
May Goal:
$300.00
Due Date:
May 31
Total Receipts:
$86.45
PayPal Fees:
$5.07
Net Balance:
$81.38
Below Goal:
$218.62
Site Currency:
USD
Powered by
EzPortal
Search
This topic
This board
Entire forum
Google
Username
Password
Always stay logged in
Forgot your password?
