Swapping the corkscrew/phillips on a SAK - A how to.
Neil · 19 · 17030
on: February 02, 2009, 08:46:24 PM
As requested by max6166 here's a quick run down of how to replace a corkscrew with a phillips driver on a SAK.  In this case a Waiter.  I've shown these pics before in some ancient thread but I can't find it  :think: so here they are again :)
Step 1 - remove the scales of your victim
Step 2 - file off the head of the corkscrew pin, you can also drill it out if you're careful
Step 3 - using a small nail or punch smaller than the pin, knock the pin out. At this stage the backspring will shift out of place. Panic not, slot your previously extracted screwdriver into place as best you can and then use a vice to compress the arrangement until the pin holes all line up.
Step 4 - take a small piece of 2.25mm diameter brass rod that you've tapered a little at one end and gently tap into through the hole. Once its in you can release the knife from the vice
Step 5 - now snip, cut or saw off the brass rod until you have around 1.5mm proud of either side (hint, dremell cut off wheel is good) and begin peening.  Do not over peen, keep checking the action to make sure you don't do it too tight.
Step 6 - rescale and admire your handiwork. Or if you overdid the peening go back to step 2 :)
click for big versions
Step 7 - Share with us how it turned out  :tu:
Neil
Offline max6166
Re: Swapping the corkscrew/phillips on a SAK - A how to.
Reply #1 on: February 02, 2009, 09:02:06 PM
What a great tutorial, Neil! I am sure many people will find this very useful. Thank you very much for posting it.  :cheers:
Reply #2 on: February 02, 2009, 09:07:39 PM
Great tutorial buddy.  :tu:
Reply #3 on: February 02, 2009, 09:22:19 PM
Making it an Apprentice.  http://www.sakwiki.com/tiki-index.php?page=Apprentice+Victorinox
Great tutorial; nice and clear.  Also a great little knife.  :tu:
Reply #4 on: February 02, 2009, 10:09:13 PM
Damn fine tutorial mate :tu:
If you've got time, maybe you could do some for Sosakonline :)
Reply #5 on: February 02, 2009, 10:17:23 PM
Nice trick that Neil - nice one!
Reply #6 on: February 02, 2009, 10:59:17 PM
Cool thanks for that Neil :tu: Very informative and clear :)
spam Offline glorn
  • His name is Robert Paulson.
Reply #7 on: February 03, 2009, 05:15:42 AM
Excellent! Thanks!
Now.. could you show us how to swap the Phillips for a corkscrew?  :think:
G
Reply #8 on: February 03, 2009, 10:52:43 AM
Excellent! Thanks!
 ::)  :D
Mike, I will do something for Sosakonline just don't hold me to a time frame :)
Neil
Reply #9 on: February 03, 2009, 12:35:54 PM
Why does that liner have the recessed section around the pin on the left?  Can't say I've seen one of those before.
Reply #10 on: February 03, 2009, 12:51:42 PM
You'll see that on newer knives.  I don't know when exactly but Vic started making their blade tangs slimmer a few years back.  Rather than put a spacer next to the blade they put that indent into the scale.  I'm not sure I've explained that very well.  :think:
Reply #11 on: February 03, 2009, 12:53:31 PM
No I get ya!  :tu:
Thanks for that.
Reply #12 on: February 03, 2009, 01:27:37 PM
Excellent! Thanks!
 ::)  :D
Neil
Good man :tu:
us Offline hawkchucker
  • I miss Benner
Reply #13 on: February 03, 2009, 08:45:27 PM
Great job on that, and that I would say is the perfect off day Sak!
Now make me one!
S
us Offline donvito
Reply #14 on: February 03, 2009, 09:41:20 PM
Great tutorial Neil thank you  :tu: :tu:, keep em coming  :cheers:
Reply #15 on: February 10, 2009, 04:48:53 PM
well I liked the look of this so much I've got a Tinker Small on the way to do one for myself.  :D
Reply #16 on: February 10, 2009, 04:55:50 PM
It is one of those tool combinations that I'm surprised is no longer available.
Neil
Reply #17 on: February 10, 2009, 05:40:14 PM
Exactly.  I hadn't heard of the Apprentice until I looked at the list on the SAKwiki.  Your tutorial happily coincided with a small Tinker coming up on eBay and so it all seems a bit serendipitous not to do one.  Plus I can put together a Tourist, another 84mm I don't have.  :D
Reply #18 on: April 30, 2009, 08:40:26 PM
I've been scratching my head a little wondering if this was possible, and lo, Neil has already figured it out, posted a tutorial and put my head scratching to bed  :tu:
Total Receipts: $105.65
PayPal Fees: $6.36
Net Balance: $99.29
Below Goal: $200.71
33%
