Leatherman Plier Head...Help Please
Demel · 12 · 1548
us Offline Demel
on: April 26, 2023, 01:19:47 AM
Hello fellow modders. I'm working on my Charge Ti, replacing the pliers head. I knew in would be a PITA I got on screw set in. I can't get the other pivot in I have the bottom end loose but can't get it to work. Any tips on lining up the plier and pivot holes?
Sent from my Pixel 6 using Tapatalk
Re: Leatherman Plier Head...Help Please
Reply #1 on: April 26, 2023, 01:25:24 AM
Fold the handle out and see if it will line up a bit better :tu: also pull yhe pliers apart some and see if that does it :salute:
Sometimes they are easy and sometimes not :ahhh
Hope that helped :tu:
pr Offline Juan el Boricua
Reply #2 on: April 26, 2023, 01:28:47 AM
Or, press handles against each other, as the fork that contains the blades' locks also pushes against the pliers head. Also, see if you can get a drift/punch as the same diameter as the chicago screw's female end, and use it to align the handle and pliers holes. Good luck!
us Offline Demel
Reply #3 on: April 26, 2023, 01:34:36 AM
Thanks Poncho. What do you mean by folding the handles out?
us Offline Demel
Reply #4 on: April 26, 2023, 02:09:32 AM
Ok, thanks I'll give it all a try.
us Offline Demel
Reply #5 on: April 26, 2023, 02:15:38 AM
EUREKA!!!!!
I took both of the ideas and ended up with a weird combination but it worked. Thanks for the help.
*Sorry for the shadow
Reply #6 on: April 26, 2023, 02:21:16 AM
I mean to position the handle with no fastener in it like you would in your pic :D
Glad to hear you got it :woohoo: :like:
us Offline Demel
Reply #7 on: April 26, 2023, 02:39:55 AM
Finished product
Re-Charge!!!
Reply #8 on: April 26, 2023, 07:51:23 PM
Looking great, Demel  8) :like: :like:
Just a plier head swap? Or did you mod the toolset any? :think: :cheers:
us Offline Demel
Reply #9 on: April 27, 2023, 04:37:04 PM
I'll try to get a picture later but it's the same charge that I modded a few years ago replacing the flat head driver with the awl.
Reply #10 on: April 27, 2023, 07:10:36 PM
Cool  8) :tu:
Offline MohiLond
Reply #11 on: May 15, 2023, 05:06:26 PM
Thank you for sharing.
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
