mini chainsaw pure cooper x brushless
Offline tool4
on: April 28, 2024, 02:56:50 PM
hello
What´s the difference between pure cooper x brushless?
thanks
Re: mini chainsaw pure cooper x brushless
Reply #1 on: April 28, 2024, 04:32:33 PM
hello
thanks
You mean pure copper motor vs brushless motor (Brushed motor vs Brushless motor)
Only Tools Matters
no Offline Vidar
Reply #2 on: May 03, 2024, 09:22:19 AM
A brushed motor uses a mechanical solution to move the magnetic field and cause rotation. A brushless motor uses electronics to achieve the same.
Compared to a brushless motor a brushed motor will be less expensive, be less efficient (a consideration for battery driven tools), make more noise, and the brushes will wear down over time.
In practical terms for something used occasionally both will be fine. Brushes take a long time to wear down and there is often replacement brushes included. Personally I have noticed that some of my brushed tools will throw sparks at times - if you're working around flamable stuff or gases that might be worth a thought too.
"Simple is hard"
"Hard is hard too"
March Goal: $300.00
Due Date: Mar 31
Total Receipts: $10.00
PayPal Fees: $0.69
Net Balance: $9.31
Below Goal: $290.69
 3%
March Donations
