I had a chance to pick up a new Spyderco Para Military G10PS ( partially serrated ) off of a forum for an exceptional deal. I traded a Spyderco for the G10PS which put me into the Para Military knife for $30 and new it’s a $220.00 MSRP Spyderco. There was one small problem. On the end of the scales, from the open end of the pocket clip, there were drilled 3 small holes, a novice attempt to relocate the pocket clip from the other end of the scales. ALL had gone ALMOST well in the brain surgery except when the brain surgeon went to put the top screw nearest the edge of the scale he tightened it up too much and snapped off the screw even with the scale. Now with no backup plan he then put the $220 ParaMilitary up for trade and I traded for it in a heart beat - I could not think of a reason not to get it for that price. I had a NEW spare PM pocket clip and screws so the removal of the beat up pocket clip would be a simple R&R operation. The problem lay at the other end of the PM, and there were a number of choices. for me to choose from.....
1. Order a new set of scales for the PM
2. Order or make my own custom scales for the PM
3. Try to match some epoxy to the old scales and just fill the 3 holes the Brain Doctor had drilled.
4. Remove the broken screw and continue down that road ( easiest and least expensive way out I could see ).
#4 Seemed do-able and the other 3 options could be viable plans I could fall back on if I got over my head or it got dicked up.
SO, with a small center punch I hit the center spot on the top of the broken screw that was exposed from the the top of the G-10 scale. Got my Dremel tool and a small carbide drill in an attempt to get the busted off screw loose. Two minutes on the drill and I was through the bottom of the metal point on the screw. Then I took another small center punch and lightly tapped on the broken screw hoping to just loosen it from the G10 scale and it moved downward enouh to expose the pointed tip of the screw. I took a pair of small mecical hemostats ( Doctor Vise Grips if you will) and latched on the the screw tip from between the opening in the oposing sides of the scales. I then turned the screw downward until it broke free of the top scale it was screwed into. Loosened the hemostats and the end of the screw fell on the work bench. Tapped all 3 holes to 440 screws, cut the 1/4" screws to the length of the holes in the G10. The screws had to be reduced in length so they would be flush with the inside of the G10 scale and not rub against the blade when it was opened or closed. Took a hand die set and threaded the scale. Put a drop of glue on the reduced screws ( remember all they are doing in covering the nasty holes that DR Strangelove drilled into the G10 scales, they are not holding anything, they are just decorations to cover empty holes.). I then took some AeroSpace 303 Protectant and sprayed the scales to make them look new again and hand buffed it off the Para Military looked presentable. Now for $30 I have an EDC Spyderco Para Military . I sure wish I had enough guts to get into doing a MOD or two on a SAK, maybe that will be next on my list of things to accomplish.. ENJOY.
02/2009
Andrew J. Gnoza, III
« Last Edit: February 12, 2009, 10:23:51 AM by eodtech »
Why do I carry a 45 ?
