Weight of single parts and tool of a Wave
Guest · 5 · 639
Charliewashburn
  • Guest
on: October 28, 2024, 09:37:59 AM
Hi, I was wondering if anyone would know the weight of the parts of a Wave. I mean the weight of the outside tools like the knives and the file etc. and the weights of inside tools. I am in a modding project to create a tool with minimum weight and maximum strength.
Re: Weight of single parts and tool of a Wave
Reply #1 on: October 28, 2024, 09:57:35 AM
Are you using Wave frames as core of your build?
Reply #2 on: October 28, 2024, 10:52:01 AM
Not sure of each individual weight but a Charge frame with lighter weight scales would yield a lighter weight tool if that is able to be done :salute:
Good luck with the mod either way :tu: :like: :like:
Offline grouch
Reply #3 on: October 30, 2024, 05:49:38 AM
I've made hybrids of the Wave, Curl and Bond models to save weight and pocket space. Are you looking at removing some of the outside tools? It may be easier to combine some of the tools to save modification time and effort. One of my favorites is the Curl/Bond with the one handed opening blade and the other half Bond. So light and smooth in the pocket. I can get you some accurate measurements if you know exactly what you want weighed.
hu Offline Mangyang
Reply #4 on: November 06, 2024, 05:17:36 PM
Here are some weights of Curl and Wave parts
Pe blade 12 g
File 13 g
Plierhead non repl. cut. 47 g
Medium flathead 6 g
Scissors 6g
Awl 7 g
Curl handle half 36 g
Bit driver with bit 9 g
Can opener combination tool 4 g
Total Receipts: $66.45
PayPal Fees: $3.99
Net Balance: $62.46
Below Goal: $237.54
21%
