2.2mm brass rod source.
au Offline PTRSAK
on: November 25, 2025, 03:34:16 PM
I haven't done any SAK mods for a while, but 10 years ago getting hold of 2.2 mm brass rod was always a bit like sourcing rocking horse pooh. Don't know if there is a widely known supplier these days but here is a link to some I found recently.
https://www.aliexpress.com/item/1005008591776795.html? MAKE SURE YOU SELECT THE SIZE YOU WANT AS IT DEFAULTS TO THE 0.8 MM DIAMETER
I bought five sticks that are 500 mm long (20 freedom inches) and now that they have arrived I've measured them up and they are bang on 2.2 mm diameter.
So I now have more than I'm likely to use in the rest of my life. :facepalm:
Also got five of 2.5 mm x 500 mm from this link, as it was about 30% cheaper (but they don't have 2.2 mm).
https://www.aliexpress.com/item/1005007324267596.html? with this listing you have to select both required length AND diameter before adding to cart.
Actually there is tons of modding supplies on Aliexpress now, a lot of it is very expensive but some of the replacement wood or brass scales are worth a look.
us Offline MacGeezer
Re: 2.2mm brass rod source.
Reply #1 on: November 26, 2025, 08:10:26 PM
Thank you for the links and your time :tu:
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
