Blackbeard · 5839 · 502792
Reply #2520 on: November 19, 2011, 06:58:15 PM
Winter is here so some vitamin C is in order.  :D
us Offline captain spaulding
Reply #2521 on: November 20, 2011, 12:31:10 AM
I actually got some fair use out of my C2 today. Philips driver mostly, but the flat-heads saw some work. My VIC Climber also got some cutting duty today.
I'm the milk man!
us Offline sawman
  • You're amongst friends.
Reply #2522 on: November 20, 2011, 12:45:28 AM
You make it look so EASY  :pok:  I'm curious to try the orange peeler myself, looks pretty handy plus an excuse to get some vitamins... "Vitamin V[ictorinox]"  :rofl: :rofl:
SAW
us Offline jerseydevil
Reply #2523 on: November 20, 2011, 03:16:55 AM
UIsed my Juice S2 and my Pioneer to adjust the vents on some radiators at home today.
Reply #2524 on: November 20, 2011, 06:03:52 PM
I used the flat driver of my wingman to make adjustments on some rope rescue gear while coastguard training today , worked very well too
us Offline airballrad
  • Gadget Addict
Reply #2525 on: November 21, 2011, 07:17:55 PM
I decided to get some of my holiday decorations up a bit early while the weather was still nice, and I used my Charge quite a bit in getting everything in place. I also need a little help from a tool I couldn't fit in my pocket.  :angel:
us Offline 82brutus
Reply #2526 on: November 21, 2011, 08:50:46 PM
From this weekend:
Farmer to whittle some dowels to fix the armrest on some stage furniture.
Used the phillips driver on my BO swisstool to drive some wood screws for assembling two of the theatre props.
Blade on my juice s2 to cut some black paracord which was used to "magic" some props offstage.
Good weekend for the multis.
il Offline Threeme2189
Reply #2527 on: November 21, 2011, 10:08:45 PM
I used my ST300 to do a bit of phone line rewiring in my ancient apartment. Mostly loosening and tightening small screws and using the PE blade to peel off insulation on a bit of wire.
now everyone has wireless access :)
us Offline Mercury
Reply #2528 on: November 22, 2011, 02:06:19 AM
I used my Wingman all day opening boxes and such.
Reply #2529 on: November 25, 2011, 03:45:38 PM
tried out the wire cutter on the trail to cut a net elastic thingy  :D cut through the metal with ease  :tu:
Reply #2530 on: November 25, 2011, 08:43:26 PM
I was a bit disappointed a few weeks ago when I tried to use my Gerber Artifact to tighten a 6mm'gutter bolt', the 'screwdriver' was no help at all  :(
But I have been using it to open paint tins this week it did a Great job!  :D
us Offline Flying Dutchman
Reply #2531 on: November 28, 2011, 01:24:59 AM
Used the saw on my Sidekick to trim up the new Christmas tree, and the blade to cut rope once I finished tying it to the Suburban.  I used the tweezers on my Style to pull some little devil (glass maybe) out that I stepped on while barefoot. Thankfully I had my keys with me & used my Fenix light and tweezers to handle the problem right there. Also hung some things for the wife in the house and used my Sidekick to remove some nails and screws from previous decor.
00 Offline Dtrain
Reply #2532 on: November 28, 2011, 01:29:55 PM
Wensday Night I used the Screwdriver/Can Opener on my RescueTool to pop out a bad Gladhand Seal...Tightened up some screws and such around the House and used my OHT PE to open a Fine Imported Lager from Piitsburgh as I watched Football on Sunday..I have gone from MultiTool on Person to Pliers and now I keep my Multi close at hand in my "Jack Pack" along with a pair of Klien Linesman Pliers/Scissors/Pump Pliers...
cs Offline edcgear
Reply #2533 on: November 28, 2011, 01:47:25 PM
I used Juice S2 and PTX Piranha to pull licence plates from truck.
Front side w/bolts which were rusted so I used S2 to unscrew and PTX to hold bolt.
Rear side was riveted so so I used PTX to pry/tear licence plate...
ΜΟΛΩΝ ΛΑΒΕ
us Offline tattoosteve99
Reply #2534 on: December 04, 2011, 05:17:42 PM
Today I used my LM wave along side my modded alox to repair my microwave. Note: never! never touch the capacitor in these things. It will kill you! After having said that and isolated the capacitor, one if the safety switches was bad. So I took it apart and repaired it until I can get a new one. Man I would be lost without my tools.
us Offline SAKplumber
Reply #2535 on: December 07, 2011, 02:53:38 AM
I have a SwissTool Spirit Plus w/ ratchet and a widgey bar in the pouch.
Busy day for my swisstool.
1.  Used the scraper to remove old caulk from a tub & shower unit to I could apply new caulk.
2.  Used the pliers to reach into a 1 1/4" trap arm brass to copper adapter to pull out some hot chrome plated brass(since it broke off & I had to heat it with a torch to loosen it).
3.  Used the ratchet & extension and my self adapted 1/4" nut driver to remove the burner assembly door from a 40 gallon gas water heater.
4.  Used the self adapted 5/16" nut driver on my bit case to remove a hose clamp holding a float on a busted sump pump.
5.  Used the widgey bar to quickly open a sump pump box so that I didn't have to open a blade to do so.
6.  Used the flat screwdriver to open the drain on that aforementioned 40 gallon gas water heater.
7.  Used the knife blade to cut an escutcheon(plastic) to snap around a trap arm.
Seems like their was more but I had a long day too and don't recall.  Just another day in the life of the SAKplumber!
Reply #2536 on: December 07, 2011, 10:20:56 PM
Used the awl on my Farmer to shave down the plastic end of a phone cord so it would fit into a jack. A bit more sophisticated than my usual "blunt force" approach to tech support  :).
gb Offline user24
  • SAK collector and all-purpose geek
Reply #2537 on: December 07, 2011, 10:23:49 PM
used the wenger can opener successfully for the first time! I've tried in the past but never understood it. Happened to see a video on youtube where someone demonstrated it and now I finally get it - you go backwards (compared to the vic way).
"Nothing endures but change" - Heraclitus.
Reply #2538 on: December 09, 2011, 10:25:51 PM
Well, just managed to pull a Captain Spaulding  :P and cut myself pretty good with my latest acquisition. I'll post pics of the new toy when the bleeding stops. It's a beaut! And sharp.......
gb Offline 5hif7y
  • tooled up
Reply #2539 on: December 09, 2011, 11:13:53 PM
used my LM micra tweezers today at work to get a metal splinter out of a fellow workers hand. and because we was outside, i used my fenix E05 to see what i was doing. great tools. luv them both. :multi:
-----5hif7y-----
us Offline 665ae
  • Formerly known as 665ae
  • blah blah blah
Reply #2540 on: December 10, 2011, 11:59:25 AM
Used my Charge AL for several cutting tasks at work tonight, as well ad the pliers to turn some rusty nuts.
us Offline turnsouth
  • There is no spoon
Reply #2541 on: December 10, 2011, 08:24:22 PM
Well I'm finally getting around to putting the vinyl flooring down in my bathroom remodel. My wife says that 15 months has been long enough, I think that we will miss that natural OSB construction site look  :D
Anyway, been using a Core to snap off the scored vinyl, and I actually used my smurfy little adjustable wrench to set the toilet. Worked remarkably well, it is well built, nice fine adjustment screw. It's a shame that they had to put a sub-par multitool on it.
Reply #2542 on: December 11, 2011, 09:11:45 AM
Nothing real exciting. The skele is on cap lifting duty tonight.  :D  :salute:
I'm the milk man!
us Offline Mercury
Reply #2543 on: December 11, 2011, 07:12:10 PM
I used my blast to cut up some awesome beef jerky yesterday.  I also dreamed last night that I used the saw on my blast to cut up some wood.  I don't know why.
gb Offline 5hif7y
  • tooled up
Reply #2544 on: December 11, 2011, 07:50:55 PM
i used my juice S2 to change the fuse on my parents xmas trees light. worked a treat  :multi:
-----5hif7y-----
us Offline Mercury
Reply #2545 on: December 11, 2011, 07:51:50 PM
Ouch, pics are a must!!!
gb Offline user24
Reply #2546 on: December 11, 2011, 07:57:13 PM
My kitchen knives are mostly rubbish, I needed a sharp blade to cut some fresh tarragon up so I grabbed whatever was to hand, a wenger evogrip.
I do like the belly on wengers.
Reply #2547 on: December 11, 2011, 08:05:48 PM
Used my LM Juice S2 pliers to unlock a door latch
us Offline Adam Clark
  • Strictly LEATHERMAN 99% of the time!
Reply #2548 on: December 11, 2011, 11:06:55 PM
MT: Super Tool 300
Task: I used the medium screwdriver to dig a skeleton key out of a crack in a base board..... I dropped the key, it hit the floor, bounced, and found the ONE AND ONLY crack int the wall base board to get lodged in!!!!! Low and behold, I GOT THAT SUCKER OUT OF THERE  :rant:
gb Offline 5hif7y
  • tooled up
Reply #2549 on: December 11, 2011, 11:23:09 PM
MT: Super Tool 300
where would we be without our multitools. lost and angry alot of the time i fink.
-----5hif7y-----
Total Receipts: $105.65
PayPal Fees: $6.36
Net Balance: $99.29
Below Goal: $200.71
33%
