Blackbeard · 5839 · 502463
Reply #540 on: December 27, 2009, 11:09:43 PM
I used the knife blade on the SkeleTool to open a package that had this in it
I have one of those , neat aren't they
Dunc
um Offline Mr. Whippy
Reply #541 on: December 28, 2009, 01:13:41 AM
Dunc
Interesting...
My Supertool didn't really look like that one.
us Offline texasflyfisher
  • I'd rather be fishing
Reply #542 on: January 01, 2010, 11:28:01 PM
I used the saw on my farmer to cut up the remains of the 10 pound holiday ham to give to my dogs. It took a while and some effort to saw through the big bone! All four dogs are in the backyard being real quite, happily gnawing on their ham bones.  :)
Offline Styerman
Reply #543 on: January 02, 2010, 12:27:16 AM
Today mine were mostly just ballast .
Chris
ni-ulster Offline cerbera147
Reply #544 on: January 03, 2010, 12:29:38 AM
Wave; to take down the outside Xmas lights  :multi:
us Offline BIG-TARGET
Reply #545 on: January 03, 2010, 12:39:23 AM
My MTs just kept my pockets from being lonely :oops:
us Offline ACHË
Reply #546 on: January 06, 2010, 03:07:36 AM
Leatherman Surge
Knife- To cut a piece of foam to use as a sponge for applying silicone lubricant.
Pliers - To pull a spring through a tube
Reply #547 on: January 06, 2010, 03:32:47 AM
Gave the Wave a good clean and polish  :multi:
00 Offline RaptorMan
Reply #548 on: January 06, 2010, 04:45:47 AM
Attacked a group of Ninja's with the BO Wave
1
us Offline turbov21
Reply #549 on: January 06, 2010, 06:46:14 AM
I used my LM c301 to open up a pair of SAK's and a Shrade cheapie I got from the hardware store.
Used my Super Tinker earlier to break down a coke box for the trash.
Offline Magnus
Reply #550 on: January 06, 2010, 10:48:57 AM
Used my Hunstman Slim to wrap some presents for the wife,  Cheers Gareth  :cheers:
i just saw this, you're very welcome mate. :tu:
Various SAKs went into cutting paper while wrapping (much faster than scissors IMO) and then my Pulse and P4 did quite a bit of unwrapping, installing batteries and cutting plastic ties etc.
how, exactly, do you cut paper with a SAK?
Reply #551 on: January 06, 2010, 12:17:59 PM
With the knife.  My mum always used a butterknife.  :D
Reply #552 on: January 06, 2010, 02:39:13 PM
I hope they were not packing BO Mini's , you would of  been SO Ninja rogered if they were  :D :D :D
Offline Styerman
Reply #553 on: January 06, 2010, 03:59:04 PM
Went to breakfast with a friend , used my Vic Soldier to stir coffee . Our overzealous Server removed all our spoons .
Chris
Reply #554 on: January 06, 2010, 07:07:22 PM
Only a "group"? :think:
Reply #555 on: January 06, 2010, 07:27:43 PM
Well all I do is have the paper on the carpeted floor*, get a rough size and use the main blade to pierce and then slice through the paper.  If the blade is sharp enough (and it doesn't have to be all that sharp), then it should glide through the paper as if it wasn't there.  if the paper is thin and nasty then it's more likely to snag but normally it's not a problem.
*try very hard not to cut up the carpet, no pressure is required whatsoever ;)
hn Offline cliosguy
  • no nacimos con miedo...
Reply #556 on: January 06, 2010, 07:32:52 PM
couldnt find the right screw driver......leatherman crunch didnt care:
10/10 (considering i didnt have anything better suited for the job)
A
Reply #557 on: January 06, 2010, 07:39:02 PM
That, to me, is the essence of what makes a good "EDC" multitool. In one word, adaptability. Good job CG :tu:
Myself, quite a boring day, but I used my Raker Ringtool to open the package containing my drink bottle holder, and the pliers on my Charge to thread the Tac Ties through the MOLLE webbing, as they were only just long enough!
us Offline thebullfrog
Reply #558 on: January 07, 2010, 01:01:01 AM
Used both a Wave and a Surge to reassemble a Kick into a custom SAK type tool. Then used my shiny brand new Swisstool to take apart and inspect the switch on a space heater.
Offline vivamanoy
Reply #559 on: January 07, 2010, 02:04:35 AM
I opened up an old radio and tightened the loose knob of the tuning dial with a cybertool lite.
Offline Fishnuts2
Reply #560 on: January 07, 2010, 02:32:14 AM
I used one of the jaws on a SOG Power Pliers as an alignment punch to install a new head on a satellite dish on someone's roof this morning.  -10 F is too cold!
W
us Offline ACHË
Reply #561 on: January 07, 2010, 05:46:00 AM
Modified a light to accept high power lithium cells.
Pliers - Used to remove the bottom spring
Hard Wire Cutter - To cut the spring
File - To smooth out the edges of the spring
Pliers- To insert the spring in its upright position.
How the heck did I go so long in life without one?
Reply #562 on: January 07, 2010, 10:56:43 AM
So far I've used my SideClip to pull out drawing pins left over from the Christmas decs and the Awl on my Farmer to start a pilot hole for a screw in hook .
Dunc
ca Offline Shane769
  • Gone Climbing.
Reply #563 on: January 07, 2010, 08:49:39 PM
So far today I have bent a metal clip back into shape which was surprisingly tough to do with only a Skeletool, 2 sets of pliers would have been ideal I think, but we managed. And opened a bunch of boxes doing receiving.
Reply #564 on: January 07, 2010, 09:11:57 PM
Used the chisel/scraper on my Spirit to remove he painted label from my ST X. Worked fantastically and the ST is way prettier now.
us Offline ACHË
Reply #565 on: January 08, 2010, 05:34:29 AM
Leatherman Surge
Large Flat Screwdriver/Pry Tool -
To demonstrate to a then potential and now satisfied customer how easy it would be to "pick" their improperly installed front door open with nothing but a flat screwdriver in 15 seconds.
spam Offline GraysonK
Reply #566 on: January 09, 2010, 02:02:14 PM
Hiker got used last night at work...a patient locked himself in the bathroom...again...and I used the caplifter/large flat head, to "pick" the lock.  Instead of being able to pop to the lock by pushing in, the lock on my side of the door looked like a very large flat head screw and simply turned and unlocked the door.  The girls were terribly impressed. :D
Offline andrea.from.roma
Reply #567 on: January 09, 2010, 03:03:05 PM
Today I've been trying (with no luck) to fix one of my family's old clocks (those with a pendulum, you know). The Spirit did very well but the problem is me: I have no idea how those things work. I'll keep trying though.
A Spirit doing stuff to a Swisstool X?
Sounds like multitool porn. :tu::D
A.
R
Reply #568 on: January 09, 2010, 04:07:50 PM
used my clutch to remove the remains of the broken key out of the padlock on my shed, it broke last night before i went to work as was getting mt bicycle out, pulled it out perfectly today,  :tu:
paul
us Offline turbov21
Reply #569 on: January 09, 2010, 07:05:43 PM
Dismantling an alarm clock. :pok: Okay, I didn't dismantle it, I took the battery cover of.  Happy now? :angel:
My Black&Decker power screwdriver's bit was too big to fit in the screw.  Instead of having to dig around my tool bag for a smaller bit or a screwdriver with a smaller head, I used my Super Tinker to open it up.
Love that SAK!
Total Receipts: $90.65
PayPal Fees: $5.47
Net Balance: $85.18
Below Goal: $214.82
28%
