Can this be done to a Charge?
TxSxB · 10 · 2537
us Offline TxSxB
on: June 10, 2010, 09:07:45 PM
http://www.equipped.com/alterpst.htm
Uploaded with ImageShack.us
He modified his file in a manner that it still 'locks' but is also easily detachable... Can this be done to my Charge TTi?
Re: Can this be done to a Charge?
Reply #1 on: June 10, 2010, 09:11:10 PM
Won't it fall out when you close the file up  :-\  :think:
Reply #2 on: June 10, 2010, 09:14:24 PM
it will still lock in closed, is the point to be able to remove it for use  :think:
us Offline TxSxB
Reply #3 on: June 10, 2010, 09:15:42 PM
Well I was thinking it might need a bit different placement of the hole to better 'hook' around the pivot so it doesn't fall out while the tool is closed. I don't know though? ???
us Offline TxSxB
Reply #4 on: June 10, 2010, 09:16:27 PM
I think the point of it is to sharpen the blade on your multi with in a survival situation?
Reply #5 on: June 10, 2010, 09:22:05 PM
 :tu:  get it now,
gb Offline ryan1835
  • buh
Reply #6 on: June 10, 2010, 09:32:37 PM
it will void your warranty and be careful cutting the file you could mess up the tempering of it
I
Reply #7 on: June 12, 2010, 01:25:50 AM
I think if I was going to do something like that with a Charge, I'd think about attaching the file where the pocket clip & lanyard ring attach.
It would require a bit more craft than the mod done to the file in the pic, but I think it would work better. Bob (J-Sews) has done this with saw blades, and a former member made me a bit driver that works with this concept and it does work well :)
gb Offline ryan1835
  • buh
Reply #8 on: June 12, 2010, 11:51:42 AM
:O thats a nice driver :P
I
us Offline TxSxB
Reply #9 on: June 12, 2010, 06:49:38 PM
OOOooo!! That is nice! :tu: You would really think Leatherman would take advantage of the potential of pocket clip/lanyard attachment, they could do a lot more with it... Long shank screwdrivers, files with different coarseness, awl/marlinespike, hacksaws, better wood saws, metal saws.... I'm sure they could find a few more to add in there, they could even stay with the bitcard system and store the extras blades/files/saws/what have you vertically in a bitcard. It would be nice.
« Last Edit: June 12, 2010, 06:59:50 PM by TxSxB »
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
