Getting Stroppy!
Re: Getting Stroppy!
Reply #30 on: July 31, 2010, 05:24:06 PM
Ooops That leather isn't leather  >:(
I was trying to strop a knife when the top surface came away from the bottom layer (it might be a very thin layer of leather)  ???
Its OK I thought to myself as I still have that big pink belt (strangely enough no one else wanted it)
I start cutting it up and....  :ahhh Bugger that's made the same way (glad I didn't send it to Zed now!)
Luckily my favourite charity shop had another belt Its being glued on as we speak so there's  another WIP (work in progress) in my garage  :tu:
gb Offline ryan1835
  • buh
Reply #31 on: July 31, 2010, 07:00:39 PM
it must be that pleather stuff that leatherman use
I
Reply #32 on: July 31, 2010, 11:58:35 PM
 :think: It annoyed me as I had wasted my time making it
live and learn I guess  ::)
Hope the new one will last a bit longer, lol  :D
Reply #33 on: August 04, 2010, 10:36:00 PM
Here's mark 2
Reply #34 on: August 04, 2010, 11:46:11 PM
Fingers crossed this time :tu:
:think:
but not whilst in use :D
Reply #35 on: August 04, 2010, 11:50:22 PM
So far so good  :D
us Offline prime77
Reply #36 on: September 03, 2010, 10:19:52 AM
I made some new strops tonight and transformed my Insingo into a razor. :D
Hair doesn't stand a chance. :ahhh
Reply #37 on: September 03, 2010, 12:22:51 PM
They look great!  :tu:
What do you use on the leather as a polishing compound?
Reply #38 on: September 03, 2010, 12:34:48 PM
Please come over here and put an edge like that on my Sebbie  :drool:
spam Offline John
  • Avatar removed by request
Reply #39 on: September 03, 2010, 01:18:11 PM
We could group send some over to him but I doubt we'd get them back through customs  :(  :ahhh :D
Reply #40 on: September 03, 2010, 01:24:05 PM
Group buy to ship him over here?  >:D
us Offline prime77
Reply #41 on: September 03, 2010, 07:01:53 PM
I have been using white and green compound. But these were made for using DMT diamond paste.
Reply #42 on: September 03, 2010, 07:19:37 PM
The 'micron' on the side makes sense to me now   ::)
I've been using white compound on mine if anyone's interested
Reply #43 on: January 18, 2011, 11:14:50 PM
I know my garage needs a tidy as I have not seen my strop for ages  :ahhh
In my favorite charity shop I picked up a couple of leather belts so started making a new strop (thought I could try a different sharpening compound  :think: maybe Autosol)
I put it to one side to fully dry
Then I Thought to myself "if a strop makes knives sharp a powered strop will do it better and quicker!"  >:D
Mmmm took one of the cutouts from my sledge making project (on right)
Put a nut and bolt through the center
Glued on a bit of belt and wraped with white electrical tape to dry (on left)
And here it is in action  :D
My Opinal is pretty sharp now
So It does work  but I'm not sure about the outcome yet as its hard to be precise with the polishing angle  :-\
I think I need to play more  :tu:
« Last Edit: January 18, 2011, 11:16:24 PM by sparky415 »
Reply #44 on: January 19, 2011, 12:04:49 AM
I like it !  :D :tu:
Reply #45 on: January 19, 2011, 12:14:21 AM
Thanks,
As I said it works but I think it would be better if it was a larger diameter and had a tool rest  :-\
I don't think I would use it on a valued knife
gb Offline Zag
Reply #46 on: January 20, 2011, 12:23:11 PM
Where can I find the polishing / stropping paste in the UK?
AloxWorld.com
Reply #47 on: January 20, 2011, 01:06:18 PM
I used this on my polishing wheel and new strop wheel
http://www.screwfix.com/prods/97236/Abrasives/Polishing/Metal-Polishing/Cutting-Paste-Bar-800g-Grey
Axminster have some good stuff (type in compound for more ideas)
http://www.axminster.co.uk/flexcut-flexcut-(gold)-polishing-compound-prod22340/
You can also use things like 'T-cut' and autosol (used for cars)  :tu:
and some people have used Toothpaste
gb Offline Zag
Reply #48 on: January 20, 2011, 01:59:31 PM
Many thanks Sparky!
Order placed   :D
AloxWorld.com
Reply #49 on: January 20, 2011, 10:17:41 PM
 :o Ooh they do them in real life as-well.. that's sad I thought I had invented something new  :-[
http://www.axminster.co.uk/flexcut-flexcut-powerstrop-leatherwheels-prod32069/
The compound seems to go in to the strop better when it is warm
I use a hot air gun or a hair drier would work :tu:
Reply #50 on: March 10, 2011, 12:41:35 AM
MK 2
Ooops the first one came to pieces  :ahhh :ahhh so thought the second one will be a bit wider
Here it is all glued together and the surface roughed up with a wire brush
Edges flattened off and sanded
coated with compound and ready to work (see how long this one holds together)
Reply #51 on: March 10, 2011, 10:42:38 AM
MK 2
Hopefully not at speed!  :ahhh
Looking very fancy :D  :salute:
Reply #52 on: March 10, 2011, 10:50:17 AM
Yes it did, centrifugal force overcame glue  :ahhh
When I use the Spork polisher I have to be aware of the noise it makes, if there's a change in pitch I step to one side and unplug the bugger quick reach for the off button  ;)
I really need to wire up a proper stop/start button  ::)
Reply #53 on: March 10, 2011, 02:40:00 PM
I've got one if you need it :tu:
Reply #54 on: March 10, 2011, 04:00:27 PM
There's one hiding in my garage somewhere thanks Neil  :think:  (a proper DOL starter  :tu: )
us Offline NutSAK
Reply #55 on: March 10, 2011, 04:17:06 PM
I'm wondering if a larger diameter wheel would work better.  The larger the diameter of the wheel, the more surface area is contacting the blade bevel.  The surface of the larger diameter wheel would be traveling at a slower rate also.
- Terry
Reply #56 on: March 10, 2011, 04:26:52 PM
You are right about the size of them, they would be better if they were bigger but I had those plywood discs laying around so I thought I will start off small  :tu:
(bigger discs at the same RPM would make the strop travel faster I think  :think: maybe  :-\ )
Reply #57 on: March 10, 2011, 05:02:20 PM
You're right Tony :)
Reply #58 on: March 10, 2011, 05:16:08 PM
That's good I was sitting here thinking  :think:
If the diameter is 3” x 3.14....ummm but if the diameter is 6” and  ummmm if I have a saucer and a plate and I hold my finger..... ummm RPM....ummmm a plate x 3.14....ummmm  :-[
Something needs to be squared maybe the saucer  :think:
Its a very long time since school   :ahhh
« Last Edit: March 10, 2011, 05:18:44 PM by sparky415 »
us Offline NutSAK
Reply #59 on: March 12, 2011, 03:12:43 AM
Yeah.  Brain fart.  :think:
- Terry
