A couple of days ago i bought this G96 filleting knife from the unsold stock of a long gone knife & fishing shop.
It is still like new and the edge for the most part was still able to shave hair on skin level, but after i gave it a few passes on the polishing paper wheel it can also whittle hair easily.
The steel is very hard, harder than Globals and Kai Shuns, and the thin & flexible blade sings while being polished.
The handle looks and feels a bit cheap but handles well, and the sheath is also functional.
Specs:
Steel: unknown stainless
Hardness: most likely harder than 60 HRC
Overall length: 12,6 inch (32,0 cm)
Blade length: 7,8 inch (19,8 cm)
Length cutting edge: 7,4 inch (18,9 cm)
Blade thickness: max 1,5 mm
Weight without sheath: 135 grams
Weight with sheath: 202 grams
