probably the worlds smallest Li-ion charger,USB.
John · 14 · 2013
spam Offline John
  • Avatar removed by request
on: October 01, 2010, 08:02:47 AM
I decided to try one of these chargers and it's that good it's replaced my two mostly used wall chargers  ;) these are custom built pre-order to your specs,mine is a 90 ma/500 ma switchable USB charger.The 90 ma is good for my 10440 3.7 volt batteries and the 500 for the higher capacity RCR123,18650,14500's in fact it'll charge any 3.7v battery  ;) the cool thing about it is: it give out a volt reading(which is refreshed every sec,so you know at a glance exactly where your battery is at.
Unplugged from your laptop it can be used as a battery tester, some other spec as follows:
Charger details:
The USB Charger is a true constant current/ constant voltage charger. Suitable for rechargeable 3.6v /3.7v li-ions.
* It will taper the current as full voltage is reached. (so you get to 4v quite quickly, and a slower finish to the charge)
* Low voltage protection (will limit current below ~2.9v to protect batteries)
* Thermal limiting
* Reverse polarity protection
* Short circuit protection
* Cut off voltage is approx 4.15v (higher ma versions typically cut off around 4.12v, lower ma versions typically cut off 4.18v)
All I can say this is a breath of fresh air to the normal cumbersome wall chargers I've used,it's much more convenient easily stored and it's travel friendly too as there's a solar panel available which you can plug the charger into,recommended  :tu:
The first pic I borrowed just so you can get a feel for how small it really is  ;)
The charger at work,
Size compared to my wall chargers,
And stored away :tu:
« Last Edit: October 01, 2010, 08:05:10 AM by John »
Re: probably the worlds smallest Li-ion charger,USB.
Reply #1 on: October 01, 2010, 09:58:45 AM
So where can one get one of these then?  :pok:  I have plans for my SF 3P and will need a decent charger.
us Offline NutSAK
Reply #2 on: October 01, 2010, 03:53:35 PM
Is this the Sabrewolf charger John?
I'm using a very similar setup to what MWClint is using in the Sabrewolf barebones sales thread on CPF, but my 4xAA power source is optional/detachable.  It's a great portable solution, but it won't be replacing my Turnigy Accucel-6 for use at home.
« Last Edit: October 01, 2010, 04:07:44 PM by NutSAK »
- Terry
spam Offline John
Reply #3 on: October 01, 2010, 07:06:31 PM
Hi Ben if you have a account at CPFMP,Go here(this will answer NutSAK'S ? too  ;) )if you don't have a account? let me know and I'll help you get what you want mate ;)
http://www.cpfmarketplace.com/mp/showthread.php?t=231760
us Offline NutSAK
Reply #4 on: October 01, 2010, 08:56:44 PM
- Terry
spam Offline John
Reply #5 on: October 01, 2010, 09:13:51 PM
Terry it's an amazing little thing I'm finding just in one day I'm getting my batteries out just to check,while I surf I charge  ;)
spam Offline John
Reply #7 on: October 01, 2010, 09:38:56 PM
« Last Edit: October 01, 2010, 09:42:52 PM by John »
Reply #8 on: October 01, 2010, 09:44:53 PM
Nice looking little electronic animal that Mate  :tu:
spam Offline John
Reply #9 on: October 01, 2010, 09:49:32 PM
Only good for Li-ions mate but yes it's a bit of a animal  :ahhh  :D
us Offline NutSAK
Reply #10 on: October 01, 2010, 10:16:38 PM
It's basically the same as the Sabrewolf barebones unit I built.  The one I have will charge from USB, 4xAA, and solar is a possibility with it also.  This one is cheaper as a complete package, but doesn't charge to 4.2 like the Sabrewolf.
I don't mind that though.  It's easier on the batteries and acceptable for a portable unit.
« Last Edit: October 01, 2010, 10:36:26 PM by NutSAK »
- Terry
spam Offline John
Reply #11 on: October 01, 2010, 10:43:42 PM
No! it doesn't charge to 4.2 but rather 4.15 which it's been said before,batteries last longer because of that  :tu: yours must be a good charger also otherwise you'd not have mentioned it  :think:
[EDIT]Anyway PM SENT!!!!
« Last Edit: October 01, 2010, 10:47:49 PM by John »
us Offline NutSAK
Reply #12 on: October 01, 2010, 11:09:48 PM
Check out these threads for another option:
http://www.candlepowerforums.com/vb/showthread.php?t=240090
http://www.candlepowerforums.com/vb/showthread.php?t=240654
I bought the barebones, standalone charger board and put together a system similar to MWClint's setup in post #12 & #14.  I used alligator clips like the pre-made USB unit.
If you're going to buy a complete unit though, I think the one John has is a better and less expensive option.  However, I would recommend removing the magnets and soldering on alligator clips for a more durable setup.
« Last Edit: October 01, 2010, 11:17:10 PM by NutSAK »
- Terry
Reply #13 on: October 02, 2010, 10:13:00 AM
Cheers  :cheers:
