SS Glue info
Jors · 5 · 1248
za Offline Jors
  • Johan Crous
SS Glue info
on: November 23, 2010, 06:43:35 PM
I am thinking of doing a MOD, but to succeed I need a strong glue that will be able to glue two Stainless steel surfaces against each other.
Is it possible. I do not want to drill holes in the multitool as it will make the warranty invalid.
Regards
Johan
LEATHERMAN: Charge TTi; Super Tool 300; Surge; Pulse; Squirt P4; Micra; MUT STD; Bit Adapter; Universal Bit Adapter; Bit Extender; Leatherman Bit Kit; SOG: Powerlock (S60); Pocket PowerPlier (S44-N); Paratool (S31-N); CrossCut (CC51-CP); Rebar.
Lightsaver LS805 Commando; LED P7 & P5 (EDC); Maratac AAA (EDC Backup); Maglite Solitaire LED.
Cold Steel Lawman; Cudeman 8" & 10" Bowie. 4 Joseph Rogers, 4 Opinel; Buck 110 & 112 & 503.
www.johancrous.co.za
Re: SS Glue info
Reply #1 on: November 23, 2010, 06:59:00 PM
Sounds like a 2 part epoxy would suit your needs.
us Offline Mike 56
Re: SS Glue info
Reply #2 on: November 23, 2010, 07:29:54 PM
Two part epoxy (J-B Weld) works real almost to good if you were to change your mind you might have a hard time getting it apart. If you are mounting something like a pocket clip clear silicone or double faced foam works good on clean surfaces.
Mike
Mike
il Offline Threeme2189
Re: SS Glue info
Reply #3 on: November 24, 2010, 01:38:20 PM
If it's going to be absolutely permanent, a strong epoxy glue is your best bet.
Re: SS Glue info
Reply #4 on: November 24, 2010, 06:12:49 PM
As said already I would use some kind of epoxy glue  :tu:
Make sure the surfaces are clean (I use IPA Isopropyl Alcohol)
If you keep it somewhere warm it will cure faster and warming will help if you want to get the bits apart in the future  :salute:
November Goal: $300.00
Due Date: Nov 30
Total Receipts: $32.17
PayPal Fees: $2.24
Net Balance: $29.93
Below Goal: $270.07
 10%
November Donations
