What oil to you use for your Knife/Tool?
TCGB · 26 · 4141
Offline TCGB
on: January 11, 2011, 07:38:36 AM
Hi,
I was just wondering what oil people aree using on there knives and MT's to keep them lubricated and resistant to corroision?
My little spyderco bug which has only been on my keys for a months is already showing signs of rust - I often have wet hands when I touch my keys so my bug gets a little damp and even just this little bit of moisture and its rusting.
The bug is going to be made redundant and now im going to have to fund a better quality keychain knife.
Im not sure of using vegitable oil was going to be ok for the little bug  :-[ but I didnt have anything else so I oiled it up with that.
what do you use?
Thanks
il Offline Threeme2189
Re: What oil to you use for your Knife/Tool?
Reply #1 on: January 11, 2011, 09:26:26 AM
I think vegetable oil gets gummed up after a while.
Most people here use some sort of gun oil, or a similar lubrication oil (3 in 1, etc').
And if you want a food safe substance, many people would recommend mineral oil.
And then there's the endless debate about WD-40, but lets not go there  :D
Reply #2 on: January 11, 2011, 12:10:22 PM
I have used a product called inox, it is a food grade lubricant. I have used it for awhile & I am more than happy with it.I buy it in one of those unpressurised pump bottles & then I use a small syringe from work with a blunt needle too draw up a couple of mls & then deliver the lubricant in a more accurate & economical way than the bottles spray applicator. :tu:
us Offline NutSAK
Reply #3 on: January 11, 2011, 02:07:31 PM
+1 for mineral oil--an inexpensive, food-safe option.
I use Nano-oil for the really sticky ones.
- Terry
ph Offline Teofilo
Reply #4 on: January 11, 2011, 02:26:43 PM
Mineral oil for me too! colorless, odorless and safe! :tu:
Reply #5 on: January 11, 2011, 02:29:30 PM
INOX is mineral oil, with a penetrating compound added.  You can save yourself a lot of money by going to the local pharmacy and buying it by the jug for about the same (or less!) than you buy a tiny bottle of INOX for.
I stay away from liquid lubes nowadays unless I really need them.  Liquid traps gunk inside itself then when it dries said gunk stays in the pivot point, eventually building up with other gunk until the whole mess is rammed in there but good and makes opening/closing difficult.
00 Offline Carlos
Reply #6 on: January 11, 2011, 03:01:31 PM
I use the oil that victorinox sells, which I think is just plain mineral oil, and ballistol.
Offline TCGB
Reply #7 on: January 12, 2011, 05:14:06 AM
Ok well I think mineral oil is the way to go in my case, now where do I buy it from?
Reply #8 on: January 12, 2011, 04:17:55 PM
You should be able to buy it in any pharmacy or grocery store.  Mineral oil is a basic laxative and is rarely dressed up with fancy brands or packaging.  Look for a plain clear plastic jug with an even plainer label.
Baby oil is the same thing, but usually has some kind of scent or other things added to it, so I would avoid it if I were you.
us Offline SuzukiGS750EZ
Reply #9 on: January 14, 2011, 07:05:13 PM
hoppes gun oil
gb Offline sousterre1
Reply #10 on: January 14, 2011, 08:07:34 PM
A rub with marine tuff cloth will prevent a blade from rusting.
All mushrooms are edible, some only once.
us Offline Pacu
Reply #11 on: January 14, 2011, 08:51:06 PM
Remington Rem Oil...good stuff
:like:    :MTO:
us Offline Singh
Reply #12 on: January 16, 2011, 03:55:30 PM
Mineral Oil.
cs Offline Vladimir
Reply #13 on: January 16, 2011, 04:19:33 PM
Nano-Oil for me.
ca Offline darkhawk
Reply #14 on: January 16, 2011, 10:40:50 PM
Air Tool Oil
Peace
Offline TCGB
Reply #15 on: January 17, 2011, 05:16:32 AM
Thanks everyone, as usual you are all so helpful  :)
us Offline New_World
  • I EDC a cell phone
Reply #16 on: February 19, 2011, 11:24:43 AM
I use victorinox oil that i got for free.
its food grade oil
Quality Control
Materials
Design
spam Offline zepla
  • Where is all that water coming from?!
Reply #17 on: February 19, 2011, 11:37:21 AM
Or go for an H-1 version of the bug  8)
Reply #18 on: February 20, 2011, 02:14:29 PM
I like WD-40, but just about any light lube is groovy.  Leatherman recommends WD-40 as well on its website.
us Offline Mike 56
Reply #19 on: February 20, 2011, 06:46:52 PM
I am a fan of WD40 as well lately i have been trying mineral oil so far i have to say i am in pressed i just wonder how well it protects against rust. It sure polishes Vic scales well. Years ago we did a corrosion test we tested Rem oil, hopes gun oil, 3in1, motor oil, Break Free,lard (salt free) and of coarse WD40. None of the oils we tested faired well against WD40.
Mike
Mike
us Offline NutSAK
Reply #20 on: February 21, 2011, 04:44:38 AM
Are you really worried about a Vic rusting?   :think:  Seriously?
- Terry
us Offline getpower
  • More money, younger women, and older whiskey
Reply #21 on: February 21, 2011, 05:06:32 AM
For the most part I use 3-in-1 oil, but I'm not really that picky and every tool that I have (with some exceptions) is a user. So, when I'm at work, and my blades get stiff, I'll use WD, Air Tool, etc...
Whatever is laying around really.
at Offline Woz
Reply #22 on: February 21, 2011, 09:16:17 AM
Victorinox Tool Oil or BlueLube. I like both.
edc-reviews.blogspot.com
cs Offline edcgear
Reply #23 on: February 21, 2011, 12:00:18 PM
+1 on WD40... I'm even cleaning my gun with it...
ΜΟΛΩΝ ΛΑΒΕ
Offline cadjak
Reply #24 on: February 26, 2011, 07:55:11 PM
Ballistol
us Offline Swiss Man
  • WIFE APPROVED
Reply #25 on: February 26, 2011, 10:14:08 PM
I use virgin olive oil, works for me and whenever I peel an apple or cut something it doesn't taste like WD40 :pok:
