The blade steel seems like a 420 steel of some sort- it's definately not a super steel, but I haven't needed to touch it up yet.Def
Ebay = $42.98 shippedI just ordered one, hoping it doesn't get loose like my green original did.......Is there a way to tighten then? I have tried everything and the funky screws wont budge, ( even heated it with a torch to loosen the lock-tight...if any? ) I was hoping to tighten it or shim it.
Quote from: dangerousatom on February 21, 2011, 10:04:48 PMHowdy Dangerous You sayin' the knife blade on yours loosened up?The blade being loose would be an understatement....I can pitch the blade back and forth about 3/8". It only had maybe 6-months of light use on it too.
I keep prowling on eBay.Ca and still no sign of any of the new Gerber MTs yet.
Quote from: Chako on February 22, 2011, 12:11:07 PMI keep prowling on eBay.Ca and still no sign of any of the new Gerber MTs yet.Travis is negotiating a group buy if you or anyone else is interested.Def
Sounds like pivot has loosened up (no thread lock perhaps?) will it tighten down, or is it something else?BTW welcome to the forum.
Quote from: Gareth on February 22, 2011, 06:54:29 PMSounds like pivot has loosened up (no thread lock perhaps?) will it tighten down, or is it something else?BTW welcome to the forum. :cheers:http://twitter.com/EDCSourceI assume the pivot you speak of is the axis pin that the blade and driver bits turn on?? If so then yes. I just took another look at it today and I can squeeze the exterior green plates closer together with my fingers, so Im still assuming its the screw that holds the one end together.....? No I cant tighten it or loosen it, its nearly impossible to get a bite on the screws that hold it down. I did use the correct torques driver, but it spun the teeth off the screw due to it not wanting to turn .....Im about ready to drill the head off and put a stainless allen with a blind nut on the other sideWish i knew about the group buy.....Id have waited a bit to save a few bucks
