Serrations Cut Into SAK Blade?
Offline pelotonjon
on: March 24, 2011, 04:15:28 AM
Is there anyone who has recommendations for a knifemaker that can cut serrations into a small SAK blade?  I'd like to send in a Deluxe Tinker to have the small blade get Spyderco-like serrations cut into it.  I might possibly do the same to the small blade on a Secretary.  Any thoughts?
au Offline Cyclone82
Re: Serrations Cut Into SAK Blade?
Reply #1 on: March 24, 2011, 08:39:26 AM
Sounds like a good idea which is also of interest to me. I wish you could get serated blades on 91mm saks. if you find someone to do it please report back here. :tu:
de Offline duder
Reply #2 on: March 24, 2011, 10:21:01 AM
There is a knife shop in my area and the owner is also a professional knife sharpener. Once I had an old GAK with a dent in the blade. That was a good reason for making serrations in this part of the blade. He did a very good job.
This is his homepage:
http://www.ballardini.de/
If Germany is not too far for you this is a good address  :tu: .
nz Offline HawkeyX
Reply #3 on: March 24, 2011, 10:32:25 AM
nice, he did a great job!
us Offline stressmaster5000
  • No PM's - just email please
Reply #4 on: March 24, 2011, 05:22:54 PM
Find yourself one of these serrated spartans.
Or maybe something like this? There are a couple different models with this blade.
This is a special order from the factory which proves Victorinox does and can do these smaller blades.
us Offline ironraven
Reply #5 on: March 25, 2011, 04:17:53 AM
If you are going to do it yourself, you could use a chain saw file, I've done something similiar on a few other knives. It doesn't take much, after the first five, six passes, check it every other stroke!
wales Offline rp252
Reply #6 on: March 25, 2011, 05:02:57 AM
I've thought about doing this myself once or twice. I reckon I'd do a crap job of it though. That german guy looks like he does awesome work.
Would the small blade on a 91mm SAK be big enough for a serrated blade? Would be hard to use as a rescue blade, could be good for other uses though.
Reply #7 on: March 25, 2011, 11:52:32 AM
Ohh wow, can you still get those serated spartans? Never knew you could get them with serated blade :gimme:
« Last Edit: March 25, 2011, 11:54:56 AM by Cyclone82 »
Reply #8 on: March 25, 2011, 09:24:03 PM
I find them on ebay once in awhile but you probably should check with one of the regular sellers here like Neil maybe.
Reply #9 on: March 25, 2011, 10:35:55 PM
You can still get them new but only as part of a Victorinox picnic set with cutlery.  Makes it expensive.  Much better to add your own serrations :tu:
Reply #10 on: March 26, 2011, 06:04:44 AM
what model is this one
Its the picnic one that has the full serations but what has the half serations?
Reply #11 on: March 26, 2011, 12:21:56 PM
Victorinox Matterhorn :salute:
Reply #12 on: March 26, 2011, 12:31:57 PM
It is :tu:
The partial serrations can also be found on the Rainier and McKinley.
Reply #13 on: March 26, 2011, 12:39:37 PM
And those last 3 are 91mm too?
Reply #14 on: March 26, 2011, 12:40:49 PM
They are but are discontinued  :-\
Reply #15 on: March 26, 2011, 01:00:09 PM
Ok. I will put a wanted add up and see if anyone knows if they are available. I tried Amazon, but none there.
Offline pelotonjon
Reply #16 on: March 26, 2011, 05:48:36 PM
I found a knifemaker to cut the serrations.  Stay tuned for pictures...
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
