I need a big bench sander/linisher
Quote from: sparky415 on May 17, 2011, 09:17:41 PMI need a big bench sander/linisher Who doesn't ? I know you are not supposed to wear loose clothing, but I am not confident enough to go without gloves, I usually end up cutting/scratching myself.
Last years fingers
Many thanks for the pictures and links Sparky, the man in the videos was not using goggles or gloves! Nice belt sander Seved, I will have to see if I can modify my bench grinder! I have seen similar ovens used in laboratories. Is that a special type? What temperature does it go up to?Addition: Thanks to your link I now have another forum to look into!
Quote from: dks on May 17, 2011, 09:25:36 PMQuote from: sparky415 on May 17, 2011, 09:17:41 PMI need a big bench sander/linisher Who doesn't ? I know you are not supposed to wear loose clothing, but I am not confident enough to go without gloves, I usually end up cutting/scratching myself. It would be impossible to hurt your self on a belt sander! Where did my fingerprints go?
Quote from: sparky415 on May 17, 2011, 09:52:43 PMQuote from: dks on May 17, 2011, 09:25:36 PMQuote from: sparky415 on May 17, 2011, 09:17:41 PMI need a big bench sander/linisher Who doesn't ? I know you are not supposed to wear loose clothing, but I am not confident enough to go without gloves, I usually end up cutting/scratching myself. It would be impossible to hurt your self on a belt sander! Where did my fingerprints go? It has happen to me many times. Its not nice, can i say lol.seved
