clever,clever leatherman
gav · 25 · 6810
Offline gav
on: September 30, 2011, 10:40:45 PM
I'll post pics on this tomorrow morning i promise.i use my phone camera and i need natural daylight for the best quality.
Anyone with the sidekick and wingman,remove the pocket clip.theres a hex nut under the torx nut so the tool wont split and you are left with a very clever bit wrench.
Very very tasty indeed.i was pleasantly suprised.a whole other tool in a tool.it fits hex bits spot on.
Is there no end to what LM come up with.
Pics tomorrow morn.
Re: clever,clever leatherman
Reply #1 on: October 01, 2011, 02:32:21 AM
Hah! I just checked it out gav. That's pretty cool :)
us Offline Accujohn
Reply #2 on: October 01, 2011, 03:26:58 AM
So, the clip is a wrench?
ca Offline jekostas
Reply #3 on: October 01, 2011, 03:31:04 AM
 :pok:
Pics!
us Offline Accujohn
Reply #4 on: October 01, 2011, 03:31:43 AM
Just checked too, interesting. Is it listed in features?
us Offline captain spaulding
Reply #5 on: October 01, 2011, 07:25:52 AM
Very Cool.  :tu:
I'm the milk man!
us Offline Accujohn
Reply #6 on: October 01, 2011, 07:49:02 AM
Reply #7 on: October 01, 2011, 09:19:28 AM
Very Cool.  :tu:
I miss the old avatar
Yea I will probably put it back in the mix pretty soon. I feel weird without it.  :D
I'm the milk man!
Offline gav
clever clever pics
Reply #8 on: October 01, 2011, 11:10:48 AM
Pics as promised.
Hope they're ok
au Offline mvyrmnd
  • Tupperware Hunter
Reply #9 on: October 01, 2011, 11:27:17 AM
Cool trick!
ph Offline edap617
Reply #10 on: October 01, 2011, 11:36:15 AM
Thanks, clever indeed.
Reply #11 on: October 01, 2011, 01:25:36 PM
Nice... I like a hidden tool :D
Reply #12 on: October 01, 2011, 01:27:12 PM
Pics as promised.
Awesome. Thanks for sharing. :tu:
Reply #13 on: October 01, 2011, 01:34:53 PM
Will it hold up to any torque though?
Reply #14 on: October 01, 2011, 02:13:05 PM
Once the clip is removed would you suggest putting the torque screw back in or leaving it out ?
us Offline getahl
Reply #15 on: October 01, 2011, 02:40:37 PM
That is pretty dang neat. How well does the "wrench" retain bits? I have a ratcheting offset bit driver, but it takes specialized bits with a ball detent. I would love a magnetized alternative that takes standard bits.
Offline gav
Reply #16 on: October 01, 2011, 03:29:38 PM
I'd leave it out dunc.i'd be afraid of losing it.any fluff that gets into the threaded bolt can easily be fished out with a toothpick.
I doubt very much this clip could be used as a wrench to do any tough jobs.its just handy that it does fit common bits.
« Last Edit: October 01, 2011, 03:31:49 PM by gav »
us Offline turnsouth
  • There is no spoon
Reply #17 on: October 01, 2011, 04:47:30 PM
So as I see it, all you need to do is take a Torx bit, place it in a bit driver, unscrew the fastener that is retaining the clip, remove the clip, take the Torx bit out of your bit driver, and then you can use the clip that you just removed with your bit driver as a bit driver.
Is it just me, or... :think: :think: :think:
us Offline Bruce909
Reply #18 on: October 01, 2011, 05:11:45 PM
I'm right with you Paul, it's very interesting that there is a hex on the pocket clip but...how would you be able to utilize this "feature" without taking the tool apart with another tool.
The hex is similar in design to the kick wrench I mean pocket clip that has the fine spline in the end of the pocket clip that coincidentally can be used to remove the PST style fasteners.  Using a hex is easier to produce and unfortunately can not be used to tighten up your PST style fasteners.
Bruce
us Offline Accujohn
Reply #19 on: October 01, 2011, 07:18:10 PM
I actually think its intended as an added measure to avoid clip movement. The hex shape prevents any side to side. That and the little tab really make it solid without over tightening the screw. The convenient size of the hex opening fits the standard nut without a special manufacturing step. All that said, one cant discount the obvious double use. Imho.
« Last Edit: October 01, 2011, 08:26:55 PM by Accujohn »
ca Offline jekostas
Reply #20 on: October 01, 2011, 08:24:57 PM
Or you can find a thumbscrew to replace the torx screw.
us Offline Accujohn
Reply #21 on: October 01, 2011, 09:14:18 PM
Again, i think leatherman found a clever way to make a cheap very solid clip without movement. I doubt the wrench idea was the main concern.
england Offline macabee
Reply #22 on: October 06, 2011, 04:53:28 PM
Looks quite ingenious, but I hope the clip is more secure than the one for the kick
"One SAK is all right. Two are too many, and three are not enough"
us Offline Accujohn
Reply #23 on: October 06, 2011, 05:05:21 PM
Rock solid, even before you tighten it
Offline patrat
Reply #24 on: October 07, 2011, 11:38:55 PM
and since you need a tool to remove the clip.....
Dual wielding leathermans!
