Scale help
us Offline Agent X68
  • "My blackberry's not working" (see sig for video)
Scale help
on: October 11, 2011, 01:05:59 AM
Hi all,
Im back, and I have a question.  I recently got some ruby plus scales for my old economy camper.  I did a test on the scales and the front scale is fine, but the liner/pins on the back scale make it fit very loose. I will have to use some glue.  So my question is, What kind of glue should I use to avoid ruining the translucent scales?
Thanks in advance,
Agent X68
Make a tool idiot proof and someone will make a better idiot. Also, Change is inevitable, except from a vending machine.
:)  See my personal text:
us Offline tattoosteve99
Scale help
Reply #1 on: October 11, 2011, 01:07:30 AM
Clear epoxy. Just a very small dab. Do not use super glue as it will seep into the pins.
Re: Scale help
Reply #2 on: October 11, 2011, 01:13:28 AM
Is there a specific brad you would recommend?  Also, would model glue for windows be okay?  It is formulated to not damage the clear window plastic, but I am not sure how strong it is.
Scale help
Reply #3 on: October 11, 2011, 01:16:22 AM
Model glue mmmmm I'm no expert but you might want to try it on the old  scales first to see if it melts/deforms the plastic in any way. Loctite brand is what I use.
Re: Scale help
Reply #4 on: October 11, 2011, 01:27:00 AM
Please excuse spelling and grammer errors as I am slightly smurfed!
Model glue(as in plastic kits such as Revell or Monogram)is a solvent formulated for non expanded polystyrene(try it on expnded polystyrene:excellent fun).It will not bond to metal.Cant comment on it fogging Ruby scales,but it can damage clear styrene.
Re: Scale help
Reply #5 on: October 11, 2011, 11:18:04 AM
Goop is recommended by many if you can get it (pain in the bum to get in the UK though).
Whatever you use make sure its its no or low solvent and remember you're not trying to use it as an adhesive more as a gap filler under the lip of the bushings, so tiny tiny amount.
June Goal: $300.00
Due Date: Jun 30
Total Receipts: $160.46
PayPal Fees: $9.45
Net Balance: $151.01
Below Goal: $148.99
June Donations
