I think he did both. I know he tested a combo tool on a 93 cause I saw it.
I saw the combo tool with a blade. I used a electricians knife with an awl. I can do a test fit for you if I had a pruner blade. I'm sure it would fit though. Try it before you enlarge the hole and test. I do that all the time just to check tools.
Quote from: tattoosteve99 on January 19, 2012, 02:14:43 AMI saw the combo tool with a blade. I used a electricians knife with an awl. I can do a test fit for you if I had a pruner blade. I'm sure it would fit though. Try it before you enlarge the hole and test. I do that all the time just to check tools.Awesome thank youQuick question: are the pins on a 93mm SAK 2.5mm?Sent from my DROID2 GLOBAL using Tapatalk
