Now we know what bit leatherman cannibalized to get the surge Awl, lolNice work, as well as with the taper on the grind btw, It Looks convex like the vic Sak awl, which is the best I've uesd. though I haven't tried a surge myself. Question for for anyone who can answer...has Anyone ever used the awl on a multi, or sak, to sew with?
Will this fit opposite the bit holder in a charge XTi or will I have to flat grind it some?
Quote from: tattoosteve99 on December 13, 2012, 12:17:50 PMWill this fit opposite the bit holder in a charge XTi or will I have to flat grind it some?Haven't tried but it's the same thickness as the other awl so I think you may have to.
Quote from: Metropolicity on December 13, 2012, 04:53:08 PMQuote from: tattoosteve99 on December 13, 2012, 12:17:50 PMWill this fit opposite the bit holder in a charge XTi or will I have to flat grind it some?Haven't tried but it's the same thickness as the other awl so I think you may have to.Thanks, what about the rebar awl? Is it slimmer?
