What did you use your Sak on today?
colt 1911 · 11141 · 1101809
us Offline ToolJoe
Re: What did you use your Sak on today?
Reply #10590 on: July 20, 2023, 03:39:25 AM
What is that bit extension you are using with the Huntsman?
fi Offline Pilotsupergrip
Reply #10591 on: July 20, 2023, 07:20:05 AM
It's the Leatherman bit adapter. Just a small amount of filing and it locks to the flathead. Several years ago I did this mod to a Spartan and I grew quite fond of it so I did it also eventually to this Huntsman
Lähetetty minun SM-A426B laitteesta Tapatalkilla
Curl, Surge, OHT, Crunch, Micra, Squirt PS4, Style CS, Huntsman, Spartan, Classic SD, Armbar Slim Cut
Reply #10592 on: July 20, 2023, 07:06:42 PM
Changed new batteries to several baby gear and inspected a walkie talkie charger that made a rattling sound. Luckily there was no loose electronics inside but a big drop of hot glue that was bouncing around the housing. The small philips bit was needed to get those extra small screws out
bg Offline DavisNikolov
Reply #10593 on: July 21, 2023, 01:12:46 PM
I find it fascinating that shortly after  I say a certain tool on a sak or a leatherman is useless to me, I find something that can be done with that tool only. Just a week or two ago I was talking with a friend about the "perfect" sak for my daily needs. I've been carrying the Spartan and said that I'd probably get the small tinker - because an 84 mm with the screwdriver rather than the corkscrew would be much smaller in pocket and that I have no need for a corkscrew in my life . Today I needed to use that outlet, but it had the child proof cap in it. I could not find the tin key that comes with those caps so I had to improvise. First I tried to pry it out with the can opener, but that did not work out. Then I had an idea ...
I'm so proud of myself  :D Wasn't there a corkscrew use badge  :climber: ?
no Offline nakken
Reply #10594 on: July 21, 2023, 01:14:31 PM
Great use, Davis :like:
Reply #10595 on: July 22, 2023, 05:32:40 PM
Thank you nakken  :)
Prepping meals with my pocket knife is something I enjoy doing.
nz Offline Storm
Reply #10596 on: July 22, 2023, 11:04:32 PM
Good to know I'm not the only one  :) Always feels a bit more satisfying to do it all with the tool you already had on board  :tu:
us Offline UscgSal
  • JOIN Knife Rights!
Reply #10597 on: July 24, 2023, 04:41:56 PM
 :like: good jobs awl  :salute:
It's me, back with new phone after retiring.
Was Tony Sal. Ts-cg@Hotmail but locked
Now Salimbenetony@Gmail
us Offline ThisAlarm7
Reply #10598 on: July 25, 2023, 02:10:59 AM
My trusty veteran Lenovo IdeaPad battery basically died...it was going from full charge to zero in about 20 min. Time will tell if this Ebay replacement works out, but I hope so. My also trusty CyberTool 34 made quick work of the full replacement. This has been a great computer. Despite just 2GB of RAM it runs so fast on the net and playing retrobox games running Debian Linux XFCE.
de Offline matzesu
Reply #10599 on: July 25, 2023, 02:55:09 PM
I ditnt used the whole potential on my Swisschamp since I got it a few weeks ago, but:
I did cut some buns ,
Used the small blade to opened some packages,
Used the tweezers to pull something..
and the scissors to cut some candle rope..
as well as the magnifier to show a customer how to tell the right direction of the candle rope (where the v is open, it’s up on the candle)
I have to say, how easy the scissors are accessible it’s awesome, on the Delemont Collection it was much more difficult to get them out whit short finger nails..
us Offline UscgSal
Reply #10600 on: July 25, 2023, 03:05:03 PM
 :like:  :salute:
ua Offline in_sympathy
Reply #10601 on: July 26, 2023, 04:31:44 PM
Used my Swiss Champ ti drop it accidentally and now it needs proper treatment
Couldn’t really decide between yellow, white and blue scales, so ordered blue and white ones. Yellow are amazing, but the ones I chose will suit my outfits better
us Offline IMR4198
Reply #10602 on: July 26, 2023, 08:39:49 PM
The good news is that you dropped it where the liner is supported by the key ring nub.  Much better than coping with a bent liner as well.  Be sure to send a photo when you decide which color to use.  I know.  You could use one color on the front and a different one on the back.... ?  Maybe yellow on one side and blue on the reverse?  Best wishes. Gary
Reply #10603 on: July 27, 2023, 01:59:53 AM
I wanted to do this long ago but sadly forgot exactly when I ordered replacement scales
Will have a pair of whites and blues this time, but surely will make a blue & yellow my next set at some point
us Offline UscgSal
Reply #10604 on: July 27, 2023, 04:17:57 AM
 :salute:  :tu:
Reply #10605 on: July 30, 2023, 10:23:58 PM
One of the power outlets in the apartment we rent in the western part of Ukraine during the war is childproof. It is located in a small room where we have an iron and an ironing board and every day my wife struggles to plug an iron into that outlet, so today I decided to finally get it fixed. Unscrewed it using a Phillips on a Swiss Champ
But found the mechanism to not be detachable sadly.
So I found me another way around - remember me complaining about some poor quality Victorinox oil I bought at some point? I used it to lube the outlet safety mechanism a little bit and now it works like a charm
Being done with that I opened a few packages with a small blade and one of those had replacement scales
So I rewarded my Swiss Champ for being a trustworthy friend today - just as always
P.S. blue and orange lanyards are on the way too
« Last Edit: July 30, 2023, 10:28:59 PM by in_sympathy »
us Offline UscgSal
Reply #10606 on: July 30, 2023, 10:45:45 PM
 :like:  :salute:
us Offline IMR4198
Reply #10607 on: July 30, 2023, 11:24:34 PM
That blue looks great.  Just like getting a new knife while still being able to keep the old one. What is the yellow and black thing that says Venture 30?  Best wishes Gary
Reply #10608 on: July 30, 2023, 11:39:08 PM
Thanks
It’s actually a Goal Zero Venture 30 power bank that has a pretty nice led light in it - I always switch the power off when messing with outlets or switches, so I turned that led light on in order to see what I’m doing :) we have quite a few different lights around here in Ukraine because of the last winter’s blackouts. Frankly speaking we expect it to be the same this year too, but I’m still hoping it’ll be ok - at least now we’re a tad more experienced
« Last Edit: July 31, 2023, 01:12:15 AM by in_sympathy »
Reply #10609 on: July 31, 2023, 05:00:46 AM
Great job on the repair, and even better that you found a use for the funky oil. The SwissChamp looks great with those blue scales, too! :tu:
Reply #10610 on: August 01, 2023, 01:06:34 PM
Used the small blade to unpack new lanyards that complete the set
us Offline UscgSal
Reply #10611 on: August 01, 2023, 02:00:48 PM
gb Offline Rizio Il Ghiro
Reply #10612 on: August 01, 2023, 03:00:26 PM
 :iagree: Great looking combo!  :cheers:
Reply #10613 on: August 01, 2023, 10:36:31 PM
Thanks I wonder why I didn’t think of it earlier - as you can see I have quite a few orange and dark blue things
Reply #10614 on: August 01, 2023, 11:49:59 PM
Just need the Garant Nomad with orange lanyard to complete the set!  :rofl: But seriously, great set you have there, Oleksander!  :hatsoff: :cheers:
Reply #10615 on: August 02, 2023, 12:51:50 AM
Frankly speaking I’ve been looking for Garant scales to put on my Work Champ
Reply #10616 on: August 02, 2023, 07:59:20 AM
Now that would look cool!  :tu:
fi Offline old Lefty
Reply #10617 on: August 11, 2023, 04:35:21 PM
It and a pair of chopsticks to the rescue after I dropped a screw under the back deck whilst cleaning the 929:
by this axe I rule
us Offline IMR4198
Reply #10618 on: August 11, 2023, 05:55:11 PM
Looks like a Hogue screw.  I keep one of those telescoping magnetic things that look like a pen.  One of the handiest tools I own.  Best wishes. Gary
us Offline IMR4198
Reply #10619 on: August 11, 2023, 06:21:56 PM
      Ordinary red Spartan went along on the gas station and mail run this morning.  Spartan wasn't called on for duty, but stood ready, lurking, vigilant, hard Swiss muscles tensed.  There in the shadows.  Well, a dark pocket anyway.  Best wishes. Gary
Total Receipts: $90.65
PayPal Fees: $5.47
Net Balance: $85.18
Below Goal: $214.82
28%
