Gingrich tactical pen secret compartment ideas
Nhoj · 25 · 3173
us Offline Nhoj
on: August 06, 2013, 04:28:41 AM
I happily received my Gingrich tactical pen today. It has been great so far. It is very robust, has a pocket clip, and takes the common and great to write with fisher space pen refills. The one I received is the version with the gun sight adjustment tool on the back. There is also a very similar one with a straight screwdriver in place of the sight adjustment tool. As I don't own a gun, when I first got the pen I thought the screwdriver version would be more useful. Then just now I got an idea. I took out a piece of SOL tinder quik and cut it in half. It fit perfectly in the sight adjustment tool.
As I already have several straight drivers in my EDC I'm glad the MTO 7th anniversary giveaway I got the pen from had the sight tool version. So now I'm wondering what else I could hide in this little compartment? Anyone got any ideas?
nl Offline bmot
Re: Gingrich tactical pen secret compartment ideas
Reply #1 on: August 06, 2013, 04:30:45 AM
Hmm... Maybe some carefully folded up spare paper money? (I can't really perceive the dimensions from the pic, so I wouldn't know, but worth a try, maybe ;) )
us Offline Nhoj
Reply #3 on: August 06, 2013, 04:40:37 AM
It is about 7/16 of an inch deep (about 1.1cm) and 1/4 of an inch in diameter (about .7cm)
nl Offline bmot
Reply #4 on: August 06, 2013, 04:41:24 AM
Really, honestly, those numbers don't mean so much to me...  :-[  But you're the one here that can try ;)  :pok:
us Offline Nhoj
Reply #5 on: August 06, 2013, 04:42:09 AM
Pills? :think:
Good idea I think I'll try with some advil.
us Offline Nhoj
Reply #6 on: August 06, 2013, 04:42:44 AM
I don't think they'd mean much to me either
us Offline Nhoj
Reply #7 on: August 06, 2013, 04:49:26 AM
Ok generic Advil sized pill didn't fit
But my allergy pills I take in spring and fall (Zyrtec) fit with some clearance!
So in allergy season I will carry an extra allergy pill in there. Thanks enki_ck! :tu:
nl Offline bmot
Reply #8 on: August 06, 2013, 04:56:26 AM
Hmm, maybe a piece of eraser? Just brainstorming here ;)
us Offline Nhoj
Reply #9 on: August 06, 2013, 04:57:59 AM
If one wanted to cut above the threads and remove the adjustment tool it would make the compartment much larger. I wouldn't do this though, I would feel like I was defacing the pen.
us Offline Nhoj
Reply #10 on: August 06, 2013, 05:02:49 AM
Dollar test failed, next a bandaid!
us Offline Nhoj
Reply #11 on: August 06, 2013, 05:07:56 AM
An average sized bandaid is close to fitting but the white padded part makes it slightly too thick when rolled up. The tiny round type of bandaid fits very well though and is more useful on a daily basis than tinder.
ca Offline Metropolicity
  • Hack Virtuoso
Reply #12 on: August 06, 2013, 05:09:12 AM
Maybe some petroleum jelly?
Ummmmm...rolled up paper for notes....the smallest charge of C4? Small chunk of magnesium. Maybe a cut down Ferro rod..
I unno, pocket universe?
Why stop now?
Shapeways - Metro's Q-branch:
nl Offline bmot
Reply #13 on: August 06, 2013, 05:12:04 AM
Hmmm, not a bad idea...  :think: :rofl:
us Offline Nhoj
Reply #14 on: August 06, 2013, 05:16:14 AM
:rofl: I could do a surprising amount of damage with the C4 I could stash in here! I thought about a ferro rod but I don't think the length is enough.
  • Hack Virtuoso
Reply #15 on: August 06, 2013, 05:18:45 AM
It'll still take out a lock :)
What's the total length?
Why stop now?
us Offline Nhoj
Reply #16 on: August 06, 2013, 05:20:50 AM
  • Hack Virtuoso
Reply #17 on: August 06, 2013, 05:22:54 AM
If I were me...I'd mod it with a steel insert with a ramped end so I could pry stuff with it. I'd have to turn down the sight tool notches and the JB weld a new thing in. :)
Why stop now?
us Offline Nhoj
Reply #18 on: August 06, 2013, 05:26:07 AM
Well if you want to pry there is a similar version with a flat driver instead of sight adjustment tool. (The bottom one in this picture)
  • Hack Virtuoso
Reply #19 on: August 06, 2013, 05:27:30 AM
Yes, but that's not what you have. So like I said...if I were me :)
Why stop now?
us Offline Nhoj
Reply #20 on: August 06, 2013, 05:28:27 AM
Modders have to mod!
  • Hack Virtuoso
Reply #21 on: August 06, 2013, 05:29:11 AM
Indubitably!
Why stop now?
us Offline Nhoj
Reply #22 on: August 06, 2013, 05:35:04 AM
Here is my list of things I might put in that I would actually use so far
•allergy pill
•small screw
•3 watch battery cells
•SOL tinder quik
•Small bandaid
Reply #23 on: August 06, 2013, 02:41:58 PM
I vote allergy pill. It's the thing you'll most likely need out of the bunch. Well except the band aid but that's better stored in the wallet.
Reply #24 on: August 06, 2013, 03:48:16 PM
Is there any clearance the other side of the closed bottom? If so, how about drilling a small hole, and putting in a mini Victorinox eye glasses driver with the driver downwards? (NOTE: I've not checked dimensions to see if the handle end would fit)
