i was talking to a buddy of mine and I was telling him about a forum discussion and I asked, dude what do you use to lubricate your tools and he said "EZ Lube"...that jerk
NECROOk so reading over this thread again and some things for me have changed. I recently got a hold of some froglube and while mostly a gun lube I wanted to give it a go on my 1095 blades and MTs.I ran across this http://www.bladeforums.com/forums/showthread.php/1057567-a-not-so-little-rust-prevention-test-round-2which I found to be interesting. Not sure what I'll do yet but it was interesting to see how froglube did.
Quote from: Aloha007 on May 11, 2015, 12:36:48 AMNECROOk so reading over this thread again and some things for me have changed. I recently got a hold of some froglube and while mostly a gun lube I wanted to give it a go on my 1095 blades and MTs.I ran across this http://www.bladeforums.com/forums/showthread.php/1057567-a-not-so-little-rust-prevention-test-round-2which I found to be interesting. Not sure what I'll do yet but it was interesting to see how froglube did. That was a good thread, and I think the take away for me is that the best 'rust preventive' lube may not be good for human, and Froglube is one of the better ones that is also food safe. The only slight drawback is the process of applying it requires heat. I kinda wonder how well it will do without the heat process(as compared to other lube)?
Don't forget about viscosities an capillary actions with lube guys. Long hydro carbon chain fluids will not penetrate where simple fluids will.Example, Hypoid gear oil will not penetrate surfaces,holes or gaps where water will flow or go through leeching or capillary action.When looking for leaks water, gas an varsol will leak through holes normal fluids will not pass through without heat or pressure. Wd-40 water displacement formula 40 was designed to penetrate siezed metals where oil will not penetrate, varsol being better then 60% of volume of wd40 allows it to wet rusty areas where light don't shine. It also has like 2 or 3 % machine oil for lubing in them instances only. Its a penetrant an cleaner that cuts\cleans heavier hydro carbon chained fluids like greases an oils. Wash with WD 40, lube with anything after, but don't just use WD by itself on loved items. Peace.3in1 is a good lube, light, flows easy an easy to clean excess off. Also cheap for volume.
Quote from: Miknitro on May 13, 2015, 04:43:46 PMDon't forget about viscosities an capillary actions with lube guys. Long hydro carbon chain fluids will not penetrate where simple fluids will.Example, Hypoid gear oil will not penetrate surfaces,holes or gaps where water will flow or go through leeching or capillary action.When looking for leaks water, gas an varsol will leak through holes normal fluids will not pass through without heat or pressure. Wd-40 water displacement formula 40 was designed to penetrate siezed metals where oil will not penetrate, varsol being better then 60% of volume of wd40 allows it to wet rusty areas where light don't shine. It also has like 2 or 3 % machine oil for lubing in them instances only. Its a penetrant an cleaner that cuts\cleans heavier hydro carbon chained fluids like greases an oils. Wash with WD 40, lube with anything after, but don't just use WD by itself on loved items. Peace.3in1 is a good lube, light, flows easy an easy to clean excess off. Also cheap for volume.Wd40 is made for nuts and bolts that are torqued one time. If you want good lubrication you have to look at motor oil and hypoid oil.I don't recommend spraying wd40 on the hinges in the doors of your house because they move allot in one year. Some thick oil will probably do better here.There is a reason you don't spray a liter of wd40 in your cars engine.I do agree that wd40 gets on the hard to reach area's easier. But after i applied the oil i move the tool in and out about then twenty times and than it is ready to go and it is good for another year of use.
The heating of the metal liquified the paste. I did move the parts back and forth to assist the liquified paste into the parts. I'd imagine a more viscous product would penetrate better however the recommendation is to reapply to further season the metal. I should also note there is a "liquid" that was supplied in the kit tho it's not anywhere near as viscous as 3and1.
