Replace the plastic inserts in the handles of a Leatherman MT with new tools?
us Offline parnass
  • 4x4 since '74
Has anyone removed the plastic inserts from the handles of the Leatherman Fuse, Kick, etc. and used the newly liberated space to add more tools?
Retired engineer, author.
Well now that's an interesting idea. I can't see any reason why it wouldn't work :think:
us Offline Tsquare
     I have not tried that but if you are going to I have seen on the site here that the clip for the kick can be used as a wrench for the pivots on the side that has the tools just not on the plier head end.
Yeah it would just take you back to the PST days and they weren't to bad  :D and you still wouldn't have the tool clumping  ::)
Are the metal in the handles thick enough without the plastic inserts for support?
us Offline David Bowen
  • Multitool Enthusiast
  • Site Manager
I have not taken a real look at my kick but I would think that the metal would indeed be too thin and it would be like the old PST days :P
David
BTW I ordered a clip for mine, can't wait to try it out. My skeletool has been getting a real workout and I thought this might be a match for those days when strength to weight ratio is a big deal.
us Offline Spoonrobot
I'm not sure if the actual handles themselves are thinner but under the inserts there is a raised section that would be a lot more uncomfortable than the old PST handles.
I knew if anybody would look into it  that it would be Spoon (again with the praise)  :D plus as always has pics to explain with for some of our (shall we say dimmer members like me :D:D Pics really help me alot I don't have to go and try to visulkize it on my own that way  :ahhh
Just now measured them both: The PST sheet metal thickness is 1mm (.039") exactly the same as the Kick/Fuse/Blast.
Offline Leatherman123
Oh, I never knew that!
B
Thats interesting  :salute:  so now if one could do something about the raised section on the handles then it might be another step towards the goal :D
Offline Tarrodemierda
  • Smells like tar and smoke.
i think a bit of tender love from angle grinder with sand disc or some dremel can easily make those waves go away.
scotland Offline Sea Monster
Can someone measure the handles of a Core?
are they the same thickness?
The thickness of the metal is one of the reasons I do not have anything from LM's "Classic" range (Kick, Fuse, Blast, Core)
(the other reason being my bizarre fear of plastic)
« Last Edit: August 10, 2008, 02:06:48 AM by Nomad »
us Offline Adam5
I measured the Core handle thickness to be 1.0 to 1.1 mm (may need a new battery for my digital calipers) for the metal alone and 3.0 mm for the metal plus zytel inserts.
Hope this helpfully  :2tu:
I hope that he figured it out before now :whistle:
Still good to answer in case they didn't  :cheers: :D
us Offline Adam5
Total Receipts: $21.00
PayPal Fees: $1.42
Net Balance: $19.58
Below Goal: $280.42
