Gerber Mp600 owners club ;)
Zed · 1330 · 172856
pr Offline Juan el Boricua
Re: Gerber Mp600 owners club ;)
Reply #750 on: August 19, 2019, 03:20:30 AM
It reminds me of my Maxped single sheath when new; sounded as if  my trousers were ripping! :rofl:
us Offline Roc
Reply #751 on: August 20, 2019, 01:27:21 AM
My haul. Not sure what I want to make yet. The thickness of the ST’s philips and sight tool has me guessing.
Reply #752 on: August 20, 2019, 01:30:04 AM
Nice trio, Roc. :tu:
us Offline Roc
Reply #753 on: August 20, 2019, 01:36:31 AM
Thanks Juan! I haven’t had to use the wire cutters yet, but wanted an infused wire cutter head just in case the replaceable cutters suck. I also prefer the blade from that one. If I do start swapping tools it will have to go into the ST. That long philips is a must. Not sure what could replace the sight tool though. Open to suggestions from anyone who has been here before.  :)
Reply #754 on: August 20, 2019, 01:59:09 AM
Don't worry much about the cutters, unless you plan to use them as your primary cutters (which I wouldn't recommend), or back ups (which I wouldn't recommend either!); mines have been fine for copper wires (electronics, house wiring, both single and multistranded), and steel wires for up to cloth hanger; for cloth wire, I notch it with the cutters and then use the pliers to "bend-cut it" . Not a single nick or shattered cutter. Mind you that I may use them once or twice  weekly. If you're mindful of what they were adapted for, you'll enjoy them for long.
Having said that, until Gerber makes replacement cutters out of tool steel or 154cm SS, my integral cutters will be the best of Gerber's.
Roc, how about exchanging the sight tool for a saw blade exchanger? Or scissors and an awl? Or ...I'll let others chime in now. :whistle:
us Offline Roc
Reply #755 on: August 20, 2019, 02:07:19 AM
Thanks for the feedback on the cutters! I guess I can just switch the plier head out when needed. I only use them for stranded copper, so I think I’ll be safe either way.
I do like the idea of a saw blade exchanger. I’d use that a lot at work, but an awl and scissors would be used just as much. Time to think.
Reply #756 on: August 20, 2019, 02:11:01 AM
Will be waitin' for pictures!!!
 :popcorn:
us Offline Roc
Reply #757 on: August 20, 2019, 02:15:14 AM
Was gonna make the bit myself to remove the tools, but came across this video. It’s kinda long, but the tool they use seems to work pretty well.
us Offline Roc
Reply #758 on: August 20, 2019, 02:47:19 AM
Well...the carbon scraper works for me as an awl. For what I use it for anyway. Scissors are on hand no matter where I’m at. Looks like I’m gonna have to find a donor for a saw blade exchanger. Need to put a file in there somewhere though.
Reply #759 on: August 20, 2019, 03:13:43 AM
Reply #760 on: August 23, 2019, 06:36:08 AM
Bladeless and Lite in BO goodness for today (TGIF!)  :woohoo:
us Offline Roc
Reply #761 on: August 26, 2019, 10:07:44 PM
Swapped out the wharn blade for the older version blade. Surprisingly easy to do.
Reply #762 on: August 26, 2019, 10:14:51 PM
 :like: :tu:
us Offline gerleatherberman
Reply #763 on: August 27, 2019, 08:33:54 AM
One of my favorite upgrades for the MP600! :like:
us Offline Roc
Reply #764 on: September 01, 2019, 12:01:47 AM
Got sick of the sight tool catching on my sheath when I’d go to put it back in after use. Decided to replace it with a file and another small flat driver.  Worked out pretty well.
Reply #765 on: September 01, 2019, 12:14:03 AM
Nice job, Roc!  :tu:
 Have you considered grinding an angle to the tip of one of the small flat driver and make a "mini awl"? That way, you get a "new" tool in the set. :think:
us Offline Roc
Reply #766 on: September 01, 2019, 12:19:25 AM
Nice job, Roc!  :tu:
I thought about that Juan, but I use an awl for starting holes for screws in wood. That’s it. The carbon scraper works great for that. It’s something I will consider if a greater need should arise though.
Reply #767 on: September 01, 2019, 12:21:04 AM
 :tu: :cheers:
Reply #768 on: September 05, 2019, 03:25:47 AM
Bladess for today.
Reply #769 on: September 10, 2019, 05:55:02 AM
Nice 600 carries Roc and Juan! :like:
Reply #770 on: September 10, 2019, 06:06:07 AM
Thank you, Chief. As long as it's a workday, it has to be bladeless. Liking the ability to exchange saw blades! :like:
Reply #771 on: September 10, 2019, 06:09:35 AM
Definitely a great feature!  :)
Reply #772 on: September 11, 2019, 05:08:59 AM
Family portrait.
us Offline Rapidray
Reply #773 on: September 11, 2019, 05:23:00 AM
Reply #774 on: September 11, 2019, 05:26:16 AM
Thank you, Sir.  :hatsoff:
Reply #775 on: September 11, 2019, 02:14:52 PM
Family portrait.
Great Gerberouping, Juan!  :like:
Reply #776 on: September 11, 2019, 04:11:37 PM
Thank you, gerleatherberman!
Reply #777 on: September 15, 2019, 04:35:46 AM
Here's to present my bladeless multiplier with lanyard ring!
Yes, I like having a lanyard ring; I'll use it every time I go up on the roof or a ladder, or where it might become hazardous if it were to fall.
Having said that, I DESPISE  having rings taking up valuable tool space (here's to Mr Pinchy, and any MP600 for that matter!), so I took upon copying the LTG's Wave et. al./Surge series alternative: an inconspicuous, unobstrussive, and elegant way to incorporate one.
My ring rides over the captive end of the female pivot, between handle and can/bottle opener.
Hope you people like it!
us Offline ChopperCharles
Reply #778 on: September 28, 2019, 12:21:15 AM
How rare are the mp600s with awls? I know the fisherman is a hard find, but occasionally I’ve seen a couple of regular mp600s without the small driver, with an awl in its place. How rare are these in silver? Or black oxide?
Charles.
Reply #779 on: September 28, 2019, 05:07:29 AM
Charles.
Not all that rare. It is the Sportsman version of the 600. Uncommon, but not rare. The Sportsman is often overlooked by collectors though.
