Gerber Mp600 owners club ;)
Zed · 1330 · 172830
br Offline Hevy (CT-782)
Re: Gerber Mp600 owners club ;)
Reply #930 on: April 10, 2020, 03:45:19 PM
Nice kit you have MTSebastian!
Very nice MP600 you have! I'm a fan of US1. Real nice small knife.
us Offline pa_strunk
  • MAJ/APA
Reply #931 on: April 10, 2020, 06:35:13 PM
Sweet Gerber Kit  :tu:
Offline MTSebastian
Reply #932 on: April 10, 2020, 09:58:55 PM
My first Gerber tool was a recoil. I lost that after 3 years.
Now I came across the MP600 and was immediately fired up.
It is really a very solid tool with a lot of potential!
Gesendet von meinem SM-A600FN mit Tapatalk
za Offline Max Stone
Reply #933 on: April 10, 2020, 11:45:19 PM
Hello everybody
I ask for admission to the MP600 owners' club I currently have 3.
The tool with the selfmade clip is my favorite. However, I don't like the shape of the blades. So I exchanged the older model.
I also filed jigsaw blades myself and built a bit holder
Stay safe folks (Image removed from quote.)(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)(Image removed from quote.)
Welcome MTSebastian to  :MTO:
And very nice setup you have.  :like: I also use the same Lansky to touch up my edges. A very good little sharpener.
pr Offline Juan el Boricua
Reply #934 on: April 29, 2020, 05:56:38 PM
(Stil) Having some time for myself, and stil unable to go to work, I wanted to use my Bladeless for EDC, but needed some kind of a "blade" for opening bags or packages, cutting plantain leaves,   or whatnot. So, I looked around and found a somewhat thick steak knife; got my Dremel out and with it, a sharpening stone and an hour now I have a removable serrated blade!
us Offline Mcfal12
Reply #935 on: April 29, 2020, 10:20:52 PM
Very nice Juan!
Reply #936 on: April 29, 2020, 10:22:38 PM
Thank you.  :hatsoff: :tu:
Reply #937 on: April 29, 2020, 11:14:14 PM
Good mod there Juan.  :like:
Reply #938 on: April 29, 2020, 11:23:56 PM
Thank you, :hatsoff:
Offline MTSebastian
Reply #939 on: April 30, 2020, 08:55:26 PM
Good day to everyone at MT.O, and your family; hope all are safe and sound.
For today, it's my SS NN MP600 and its kit, still using my replacement C-clip from this post: https://forum.multitool.org/index.php/topic,84221.0.html
So far so good ... :whistle:
Hey Juan, can you tell me more about your Accessoires? I'm interested in your jigsaw blade. How do you make them fit?
Greetings, Seb
Reply #940 on: April 30, 2020, 09:12:34 PM
Hello MTS; the jigsaw blades are standard u shank/"universal blades. The serrated edge "knife", was made by measuring the SE blade from my MP600 Basic, transferring and adjusting that measurement to an old steak knife (think Longhorn's/Applebee's/Outback's in the States) andthen tracing the shank onto what will be the tang. Drill hole with tungsten bit, finish off with diamond round bit, and then cut shape with cutting disc ( I used regular; may use reinforced one). Finish by polishing cuts with sharpening stone/sandpaper cuts.
The "awl bit", was made following a post from here. At the moment, I'm busy but later on I'll look for the link ( it's something like "awl bit for wave/charge"). Hope this helps; enjoy!  :tu:
Reply #941 on: April 30, 2020, 09:53:57 PM
Reply #942 on: April 30, 2020, 10:12:26 PM
Looking back, sorry that maybe I misunderstood you! :facepalm:
If you're talking about the jigsaw blades from the SS Mp's kit, those are t shanked blades. I ground the nubs off, measure carefully for shortening it and marking where it will ride (another alternative would be to remove one of the tools and trace shape); using a 1/4" cylindrical grinding stone (again on the Dremel) I ground out "the hook". This is so that it fits over the female pivot post, between handle and can opener. Mind you, not all blades have the neccessary width and, will not fully lock ( it will not close on you during use because it rides against the chassis/handle like a regular tool and there is some resistance if you try to fold it in without operating the sliding lock). If you have any other questions or inquiries let me know. Hope that this now helps! :multi:
Offline MTSebastian
Reply #943 on: April 30, 2020, 10:30:02 PM
Hey, thanks for your answers! Your knife mod in a bladeless is cool! I spontaneously come up with an idea. You could make a fork and a spoon to fit into the tool holder that would be perfect for camping!
That with the hook is a good idea! I only get the T shaft blades here in Germany. That's why I filed them thinner and thinner so that they fit
I will put the Awl bit on the ToDo list.
Reply #944 on: April 30, 2020, 10:38:25 PM
us Offline ChopperCharles
Reply #945 on: May 05, 2020, 05:49:56 AM
I’m still loving my modified MP600. I have other gerber tools and other mp600s, but I always come back to this as my heavy duty workhorse tool. I originally made it with leftover parts from junk tools. It’s got quite a few diesel parts in there, including the scissors, large flat driver, saw, and bottle opener.
The plier heads have been ground so they fit completely in the handles. I ground a scraper into the end of the file. I drilled and tapped holes for a pocket clip. The latest mod was expensive - I searched high and low for an mp600 with an awl. Found one and swapped it in. Now it’s the perfect tool for me.
Charles.
Reply #946 on: May 05, 2020, 07:58:18 AM
Good work CC  :like:
I was looking at the clearance behind the pliers when closed, and I recon that there’s a bit of space left to have the pliers slide in a little deeper. I may look at extending the slide slots to see...
Reply #947 on: May 05, 2020, 05:01:07 PM
I did that too. Just a quick hit with a dremel and I got an extra 2mm of space to slide them in further.
Charles.
Reply #948 on: May 05, 2020, 05:15:31 PM
Nice mods um the MP600 CC!
Great tool
Reply #949 on: May 05, 2020, 06:29:26 PM
I did that too.  :t[/s]u:
[/s]
Charles.
Not this...
Nice and clever mod, thanks!
Reply #950 on: May 05, 2020, 06:32:11 PM
Charles.
...this!
Reply #951 on: May 10, 2020, 04:49:13 PM
For today, its my Gerber Duo. My "bladed" bladeless helped me make an ikebana for my Mom; hope she likes it!
Happy Sunday/Mother's Day!  :tu: :cheers:
Reply #952 on: May 11, 2020, 08:16:55 PM
Very nice duo Juan!
And beautifull flowers
Reply #953 on: May 11, 2020, 10:41:41 PM
Charles.
I measured and cut the slots back 3mm with my Dremel. The blunt nose MP600 pliers now retract fully. Much better.   :cheers:
Reply #954 on: May 12, 2020, 03:34:12 PM
Nice mod there, Max!  :like:
Reply #955 on: May 12, 2020, 04:47:46 PM
Thanks Juan.  :hatsoff:
Now they match...  :cheers:
Reply #956 on: May 12, 2020, 05:01:01 PM
Nice, very nice.
 :like:  :tu:
Offline MTSebastian
Reply #957 on: May 12, 2020, 08:52:48 PM
Really nice
Reply #958 on: May 12, 2020, 10:34:01 PM
Thanks guys.  :hatsoff:
Reply #959 on: May 12, 2020, 11:23:23 PM
Keeping up with the "boredom binge", I now have a plain edge blade on my Bladeless; following the results from my serrated edge venture, I bought a Dollar Store paring knife to make a pseudo spear point knife blade ( the spine has no grinding to the point, it merely mimics the curvature of the belly) and, here's the result!
 :woohoo:
