Show off your Sak mod's!
wales Offline magentus
  • mmmmm SAKrelicious
Re: Show off your Sak mod's!
Reply #4140 on: November 03, 2015, 02:06:48 PM
us Offline s1xty7
Reply #4141 on: November 03, 2015, 07:11:49 PM
Thank you all for the info, I have a local hobby shop or two that needs visiting...   :tu: I had seen the Apprentice but unfortunately also saw the prices some bring! Figured I'd probably spend twice as much, bugger a couple perfectly serviceable knives, curse a bit, and try to make my own...   :)
Yea, some of those out of production SAKs get crazy expensive.  I was lucky enough to have someone give me a beat up Apprentice I was able to get back to functional but I'll probably make up some too.  Even though the Apprentice is compact and has a great tool set, the backside phillips has some limitations on strength so I'll likely make up some Scientists.  That's another out of production and crazy priced SAK with a good toolset.  Its like a 91mm Apprentice with an inline phillips and magnifying glass added and corkscrew on the backside instead of the phillips.  I'm not a corkscrew fan nor do I need the small driver it can hold but I haven't seen any non backside tool scales for 91mm or I would drop those altogether.
Good luck with your mods!!
pl Offline ALM
Reply #4142 on: November 04, 2015, 02:34:30 PM
Titanium Tool 58mm
pl Offline ALM
Reply #4144 on: November 04, 2015, 10:19:17 PM
Pioneer with Scissors Burnt Bronze Cerakote. Titanium screws. Brass liners.
us Offline Monrogue
  • Wooooo!
Reply #4145 on: November 05, 2015, 02:11:32 AM
Nice one ALM :tu:
K-Tibbs
Offline Tom Schneider
Reply #4146 on: November 07, 2015, 04:08:48 PM
I have one ALM custom and it is amazing!! Now the problem is the more of his work I see the more I want!
wales Offline hiraethus
  • I brake for cake
Reply #4147 on: November 08, 2015, 04:39:37 PM
Making some brass liners for Pioneers
  • I brake for cake
Reply #4148 on: November 08, 2015, 04:41:10 PM
This mod is a subtle one:
Reply #4149 on: November 09, 2015, 09:54:17 AM
I like the work pics.   :tu:   :tu:
  • I brake for cake
Reply #4150 on: November 09, 2015, 10:43:13 AM
I should have taken more, but only managed to snatch a bit of time in the evenings to make a start on these.  The process is a bit laborious, but it's nice when they start to really take shape like this.
gr Offline firiki
Reply #4151 on: November 09, 2015, 11:09:53 AM
That's one thick liner right there!  :o  :D
 :drool:  :tu:
  • I brake for cake
Reply #4152 on: November 09, 2015, 12:12:43 PM
 :D  It's 9 or 10 liners all stacked up so I can shape them in one go.  TBH it's a bit thick for my belt sander and fret saw to handle - I'd be better off doing them 4 or 5 at a time.
gr Offline firiki
Reply #4153 on: November 09, 2015, 12:38:55 PM
Fret saw? You're cutting them manually?!
I'm both jealous and inspired. I'll mod me a SAK or three, one day :tu:
Reply #4154 on: November 09, 2015, 12:42:30 PM
Yeah, a SAK of mass destruction
gr Offline firiki
Reply #4155 on: November 09, 2015, 12:54:58 PM
And I'll call it magentus' silence (at last)...
  • I brake for cake
Reply #4156 on: November 09, 2015, 01:00:03 PM
 :salute:
Yep, all manual - except for the belt sander.
The way I do it is:
Cut the blanks using tin snips (21 mm x 100 mm or so) out of 0.8 mm brass sheet.
Flatten the blanks as they get bent during cutting.
Drill and deburr one pivot hole in each blank.
Stack the liners and clamp together with a single factory liner as a drilling template, using a 3mm pin through the already drilled hole as location.
Drill the other two holes in the stack - this ensures that they're all in the same place.
Separate out the stack and deburr the holes as necessary
Rebuild the stack with a factory liner at each end to act as a guide for the sanding - bolt and rivet together tightly.
Hacksaw as much material from the outside as possible.
Use belt sander to get the outer edges close to the liners.
Use a combination of hack and fret saw to remove the material from the middle.
Belt sand the bits in the middle you can get to.
Keep going at the shaping with files until very close to the shape of the factory liners, then switch to aluminium oxide/silicon carbide paper and polish to finish.
You really should. :pok:
Reply #4157 on: November 09, 2015, 01:00:20 PM
will it have a fish scaler?
gr Offline firiki
Reply #4158 on: November 09, 2015, 01:19:57 PM
Yes, it is useful in pic-nics and other occasions. It will be called magentus' sorrow  :angel:
gr Offline firiki
Reply #4159 on: November 09, 2015, 01:29:01 PM
 :salute:
The way I do it is:
I'm certainly eager but if this is to happen radical changes must be made in my life first. Like, getting a bench to work on and getting some more tools and a place to put said bench, also finding the time. Baby is the top priority right now though, things are tough I can tell you. Alternatively, if only I could manage to be granted free access to a friend's workplace...
Thanks for the description of the process :tu: I'm not sure if you're encouraging me or demoralising me, though. :D
  • I brake for cake
Reply #4160 on: November 09, 2015, 03:11:26 PM
Totally understand about the time kids need, and hope that all's well.
You don't need much to get started with modding, particularly if you're doing cellidor stuff - a drill, some files, punches and a hammer will do to start with.  You could use my tools anytime you like, but I guess it's not that convenient.  Time seems to be my most precious commodity.
Reply #4161 on: November 09, 2015, 03:17:37 PM
What H says.
For basic modding you really don't need much at all in the way of tools. Time is what you need and parenthood doesn't come with an Hermione Granger 'Time Turner'.
Drop your end of times shenanigans though and you'll have plenty of time for modding.  :D
gr Offline firiki
Reply #4162 on: November 10, 2015, 11:41:02 AM
So far so good. Thank you. :salute: During workdays and if there's nothing else to do after work I get to see the lil' one for about an hour before bedtime routine, I give him that so we can spend some more time together. His mum is also working so in the weekends we try to spend as much time together as a family as possible while getting everything else done as well  :ahhh
In 91mm size, the Huntsman and Handyman models have me covered. Alox is what I'd like to mod.  :climber: That's a very kind offer on your behalf, I'm afraid hopping on a plane to the UK every now and then would be a tad inpracticable, though. On the other hand, my friend works at a place equipped with all sorts of tools but he doesn't own the place :-\
Bottom line is I need a clamp vise and a drill first, then get my priorities all set and then just take the leap. Hopefully you all will be hearing about how that went :cheers:
What H says.
But... this is who I am and what I do! I must show the kid how it's done  :pok:
I doubt they'd like to see me try my hand at modding SAKs at work. Letting me usurp the computer when things are calm is enough, I should think ;)
Reply #4163 on: November 10, 2015, 12:15:56 PM
'magentus' sorrow' has a ring to it. Like one of Iain Banks spaceship names. I like it and approve. I hope this doesn't upset you further.
gr Offline firiki
Reply #4164 on: November 10, 2015, 12:40:25 PM
On the contrary, I am pleased to hear that. Just that, you're the one that's supposed to be upset by magentus' sorrow when put to use ??? :think:
Reply #4165 on: November 10, 2015, 12:48:29 PM
And yet here I am as chipper as a dog with a bone! Strange eh? Almost like I have no real worries at all!
gr Offline firiki
Reply #4166 on: November 10, 2015, 01:07:25 PM
Bonkers seems more acurate to me :D. Fear can do that to a man, you know...
Reply #4167 on: November 10, 2015, 01:09:50 PM
I may be suffering from Blechkoller.
gr Offline firiki
Reply #4168 on: November 10, 2015, 01:18:36 PM
The Beatles- Yellow Submarine
Reply #4169 on: November 11, 2015, 03:03:44 PM
If only life aboard my U Boat was like that.
My Spargel keeps misting up so even I don't know where I am.  :facepalm:
