Show off your Sak mod's!
Re: Show off your Sak mod's!
Reply #4831 on: December 05, 2016, 02:38:45 AM
New page banana man dance
:nanadance:      :nanadance:
fr Offline hulk.
Reply #4832 on: December 05, 2016, 10:16:27 AM
The parcel hook is also pry bar/ flat screwdriver http://forum.multitool.org/index.php/topic,5287.msg1365950.html#msg1365950
The corkscrew was replaced by awl.
Other tools: scissors, blade and... fork   :rofl:
I do not know if it's feasible.
But there is little to be something to do on the heel of the hook to avoid the right left movement.
The mod is nice the fork makes smile
00 Offline WWW
Reply #4833 on: December 31, 2016, 09:50:25 PM
Not mine but pretty sweet. I don't think I saw this one over here.
Reply #4834 on: December 31, 2016, 11:03:54 PM
Pretty cool mod on that SAK  :o :like: :like:
de Offline Sunshineinwinter
Reply #4835 on: January 03, 2017, 10:57:38 AM
Hello,
wanted to make interchangeable scales from wood for my Executive. A change of the liners was necessary, now they are from thick brass, the scales are screwed on. They are of Red Shisham.
Reply #4836 on: January 04, 2017, 10:46:12 PM
Hello,
Those are awesome looking Sunshine :o :like: :like:
wales Offline hiraethus
  • I brake for cake
Reply #4837 on: January 12, 2017, 12:22:50 PM
I recently traded a Grand Prix mod with Gareth but decided I missed it so built another.
Used a file spring that can accept a back tool and fitted the flat driver instead of the chisel.  No nail file hook on this one, unfortunately.
gb Offline Oxford_Guy
Reply #4838 on: January 12, 2017, 09:10:33 PM
Love this! I've been considering buying an actual vintage Grand Prix (with the fine driver on the back of the file, it won't have the hook, though), really like the tool combo on this
"We broke into Mir using a Swiss Army knife. Never leave the planet without one." - Chris Hadfield, Astronaut
Reply #4839 on: January 12, 2017, 09:15:23 PM
+1 That is a really nice mod Hi :tu: :like: :like: :like:
id Offline jaya_man
Reply #4840 on: January 13, 2017, 01:52:25 AM
+2 :like:
Offline redneckbear
Reply #4841 on: January 19, 2017, 09:14:57 PM
I would say the screws make it much easier.  I have no experience with pin work, but it sounds like a bit of a pain to me.  This was the first tweak I've done, and had no issue with it.
What screws are that, pls? I'd like to do some modding of my own and using screws seems to be much easier than the pins ... :)
se Offline Fortytwo
Reply #4842 on: January 19, 2017, 09:29:53 PM
Those are what Syph007 uses, I think he mentioned his secret in And so it begins.... (My adventures into Alox!). They are not necessarily any easier than pins however, at least not if you're modding for your own use, since it requires drilling out the rather hard tools to make them fit. I believe they are 1/8" instead of the standard 2.2 & 2.5 mm but I'm not certain.
Offline redneckbear
Reply #4843 on: January 19, 2017, 09:33:54 PM
Oh, drilling out the tools? I don't want to do that ... :o
Thanks for your answer! :)
se Offline Fortytwo
Reply #4844 on: January 19, 2017, 09:37:29 PM
If you can source the pinstock or if you are only planning on removing layers the actual work is not that difficult (although it's preferable to work with Cellidor since that hides any imperfections).
us Offline Monrogue
  • Wooooo!
Reply #4845 on: January 20, 2017, 01:52:08 AM
I think T6 torx :think:
K-Tibbs
00 Offline timganev
Reply #4846 on: January 20, 2017, 10:17:53 AM
For some time I wanted a Compact pattern in 84mm.
I started this mod with 84mm Waiter, 91mm scissors with parcel hook (the parcel hook was already modded to pry bar) and aluminum plate from ancient hard drive  ;)
00 Offline timganev
Reply #4847 on: January 20, 2017, 10:18:32 AM
The hard part is to drill in victorinox steel… I give up the idea to make a new hole in the scissors and just enlarge all holes to 3mm (destroying cobalt drill bit in the process  ).
Whit the new scales I assembled back the Water and started the scissors spring mod
« Last Edit: January 20, 2017, 10:20:42 AM by timganev »
00 Offline timganev
Reply #4848 on: January 20, 2017, 10:19:44 AM
When I finish to balance the spring tension I will put the permanent bolts (they will be aligned
With the scales) and a cross on the scales  :D
gb Offline shibafu
Reply #4849 on: January 20, 2017, 11:07:09 AM
Nice job, Timganev.  That is a novel source of scale/liner material.
id Offline jaya_man
Reply #4850 on: January 20, 2017, 11:22:10 AM
Awesome mod Timganev... :cheers:
Reply #4851 on: January 20, 2017, 08:10:29 PM
Nice one Timganev!
wales Offline magentus
  • mmmmm SAKrelicious
Reply #4852 on: January 20, 2017, 10:00:29 PM
Excellent mod timganev! I like your innovative thinking.  :salute:
id Offline jaya_man
Reply #4853 on: January 26, 2017, 07:35:58 PM
A good friend bought a 2nd hand Compact and asked the seller to ship it straight to me for some mod...
A simple hack to morph it into a Trail Guide with a fine screw driver on the back of the metal file. This is actually my first mod for 2017.
It is now on its way to my friend to serve edc duties. :cheers:
« Last Edit: January 26, 2017, 07:37:33 PM by jaya_man »
pl Offline theredel
  • The Groke
Reply #4854 on: February 02, 2017, 06:34:35 AM
Another fatman I maded:
nl Offline Ron Who
  • I'm blue!
Reply #4855 on: February 02, 2017, 08:58:29 AM
I like what you did there! I also have a question about the fork. The answer may be in the video but my PC doesn't have sound, so: Is that a Mikov fork? And what kind of spring is it on? Do you think it could be fitted in a 84 mm knife?
pl Offline theredel
  • The Groke
Reply #4856 on: February 02, 2017, 11:12:27 PM
Yes, it is Mikov, spring is from Victorinox, I don't remember from which tool (yes, I have big mess in my pocket knife parts) :-)
84 mm: maybe with huge regrind, and drilling hole for pin in completely different place, bcs this fork is quite big.
If you live in Germany / Austria, maybe you can find polish knife Gerlach with fork, it's lot closer to 84 mm size.
Or maybe form from Richartz, but I'm not so sure...
id Offline fong
Reply #4857 on: February 24, 2017, 03:37:23 PM
The new apology join. regular discussions on local forums.
SAK,My first modding is compact tinker with ecoline acale,I chose it because it was quite nice with minor scratches
Reply #4858 on: February 24, 2017, 04:00:48 PM
Welcome fong!  :cheers:
id Offline fong
Reply #4859 on: February 24, 2017, 04:11:00 PM
Thanks magentus 😊
