Sog help needed , its in bits
Dunc · 18 · 3311
on: June 17, 2008, 04:17:53 PM
I ordered a V-cutter for my powerlock to replace the scissors but Heinnie Haynes sent me a line cutter instead. I thought I'd keep it but when I installed it , it was for the older powerplier and had no notch for the lock :( I have found a thread about it since on here  ::) So I phoned them up and they said no probs send it back and we will send you the right V-Cutter . Just got an email saying they can't source one and have refunded my money . So can someone show pics please of how to put the scissors back in and also the correct position of the two washes please .
I'm not a happy bunny  :( :( :( :( :( :( :(
Dunc
Re: Sog help needed , its in bits
Reply #1 on: June 17, 2008, 05:37:03 PM
That sucks.  :(  Have you tried going directly to SOG for one?
Reply #2 on: June 17, 2008, 06:14:42 PM
Not yet , I'm fed up with it now and just want to put it back together  :(  I will try again later .
Dunc
Reply #3 on: June 17, 2008, 06:16:33 PM
Dunc
Tough break mate :(, but I'm sure someone'll be along soon to show you what's what :)
us Offline Spoonrobot
Reply #4 on: June 17, 2008, 06:22:44 PM
I don't know about the washers but I've got pics of the instruction sheet for the scissors on the way in just a minute.
Reply #5 on: June 17, 2008, 06:32:23 PM
Photobucket is down, I'll attach the pictures to the post. Sorry this is the best I can do, I installed the scissors on a Paratool and not a Powerlock.
Are the two washers the thick kind? Since the scissors is not the same thickness as other implements I think they're for taking up the slack and making everything fit. You should just be able to put them on the outside of one of the handles and it should function fine?
Reply #6 on: June 17, 2008, 07:10:38 PM
Spoony thats great  :D Thanks . I put it back together but the washers didnt feel quite right . I'd really like to know their original position .
Dunc
Reply #7 on: June 17, 2008, 07:24:45 PM
Help is on the way... I'll take some pics of mine and post them for you.
Reply #8 on: June 17, 2008, 07:31:34 PM
Def your a star  :D
Dunc
Reply #9 on: June 17, 2008, 07:41:06 PM
Hope these help...
Reply #10 on: June 18, 2008, 05:36:25 AM
All sorted and back together  :D Many thanks Spoony and Def  :D
Dunc
Reply #11 on: June 24, 2008, 03:41:05 AM
Glad to be of service!   :salute:
Reply #12 on: September 29, 2008, 08:25:39 PM
Well I don't think I put it together right . The tools were in the right place but the washers werent and caused the tools to lean a little . This was also noticed by a member ( cant remember who ) at the meetup . So when I got home I took it to bits again then got fed up with trying to get the scissors in  >:(
Tonight I just remembered it and had another go , I think I got it right this time  :D
Before I put a drop of loctite on the thread and do it up to the right tension does this look right ?    I put the two washers , one at each end against the frame
Dunc
Reply #13 on: September 29, 2008, 10:49:10 PM
No it still wasnt right  >:( The 1/4 inch bit adapter was catching on the bottle opener . Took it to bits again and move one of the washers to go between these two tools . Loctite applied right tension on the tools , blade sharpened and a little oil added to the joints  :D Looks like it could be back in service soon  :D
Dunc
gb Offline Roadie
  • Hello...is this thing on?
Reply #14 on: September 29, 2008, 10:54:49 PM
Thanks to this thread i'm gonna be taking a fair few pics of my Powerlock in case i ever get the urge to take it apart! :D
00 Offline Freudian Frog
Reply #15 on: September 29, 2008, 10:55:25 PM
Oh my... now I really need a SOG multitool...
Got those frog legs.
Reply #16 on: September 30, 2008, 03:16:18 AM
It's always good to learn from Dunc's another person's screw-ups! :D
Reply #17 on: September 30, 2008, 05:46:54 AM
 :D The things I do for this site  ::)
 Also if I was to strip the thread on the handle bolts , how easy is it to get replacements ?   And no I haven't done that yet  :twak:
Dunc
Total Receipts: $90.65
PayPal Fees: $5.47
Net Balance: $85.18
Below Goal: $214.82
28%
