Ok, i've got it since 4 months , and i'm quite disappointed.The sping oppening mechanism is funny, the inner tools are quite ok, but:The plier is weak, i mean really weak, sometimes i try to cut something and they just got stuck (and impossible to move the plier again) or didn't cut well, i already had to cut a wire with my style PS because my switchplier 2 wasn't wanting to cut it!!The inner tool are a pain in the --- to deploy, you need to open the plier and the piano spring is useless.So ok it funny but not really convenient as i never know if in can trust my plier.a video to explain the problem, maybe i'm the only one to have it.https://youtu.be/4uyFbU1ALqQ
Quote from: hellsing on February 13, 2016, 07:13:52 PMOk, i've got it since 4 months , and i'm quite disappointed.The sping oppening mechanism is funny, the inner tools are quite ok, but:The plier is weak, i mean really weak, sometimes i try to cut something and they just got stuck (and impossible to move the plier again) or didn't cut well, i already had to cut a wire with my style PS because my switchplier 2 wasn't wanting to cut it!!The inner tool are a pain in the --- to deploy, you need to open the plier and the piano spring is useless.So ok it funny but not really convenient as i never know if in can trust my plier.a video to explain the problem, maybe i'm the only one to have it.https://youtu.be/4uyFbU1ALqQWhen the pliers stick closed my first thought is that there might be a bit of metal in the cutters folded over- that is usually why plier jaws won't open smoothly.But then at the end it seems to pop open ok. I'll send Chris@SOG a message and see what he thinks.Def
My scissors get hung up right before folding in. The handle hits the cross member for the safety locks. If I pinch the tip of the scissors to close them and hurriedly push them in, it works, but there is a click.Any idea how to fix this? I should also note they don't fully close. They always want to stay open a little. Is this normal for a sog?
Quote from: hellsing on February 13, 2016, 07:13:52 PMOk, i've got it since 4 months , and i'm quite disappointed.The sping oppening mechanism is funny, the inner tools are quite ok, but:The plier is weak, i mean really weak, sometimes i try to cut something and they just got stuck (and impossible to move the plier again) or didn't cut well, i already had to cut a wire with my style PS because my switchplier 2 wasn't wanting to cut it!!The inner tool are a pain in the --- to deploy, you need to open the plier and the piano spring is useless.So ok it funny but not really convenient as i never know if in can trust my plier.a video to explain the problem, maybe i'm the only one to have it.https://youtu.be/4uyFbU1ALqQupdate from a long time, sorry for the digging.I finally find a moment to analyze, dissec, and optimize my switchplier. The harder part was to find time, i did it with one of my newborn twins on the knee. no vids and i take sh**y pics only, not worth posting them.The problem with my switchplier was the steel rod that action the plier: it was to short of 2mm. The handle inner length is 14 mm, so the stell rod must be 14 or a bit less. Mine was 12mm. So when i press the handle, the inner handle split away and the plier cannot close cpmpletly. And the plier was stuck as shown in my previous video.I just make a new steel rod 13.8mm long, 3.1 mm diameter and my switchplier is now as good as i wanted it from factory.Quite disapointed by this design or tolerance error, but if i can repair it, its ok for me.Sorry if it has already said by another member, but i've been extremly overcharged this last 2-3 years (wedding, house, babies etc)
Maybe you could report the issue (and how you solved it) to SOG?
