Olfa Cutter (Hobby and Crafts knife)
ch Offline Etherealicer
on: May 26, 2015, 11:47:03 PM
So I got this new cutter, which I think is kinda interesting as it has a very thick blade.
Now, I haven't used it yet, apart from a couple of test cuts, but the grip is very comfortable. The blade is huge for a cutter (55mm edge) and its very strong (there is almost no play when opened and secured).
I think there is enough blade that you could sharpen it, which would allow for an interesting combo with a blade that can both be sharpened and/or replaced.
Dimensions: 116 x 22.5 x 5.5 mm (without the screw, with the screw its 10 mm thick).
Weight: 50g (that is a very rough estimate, as my scales are not that precise)
Pros
- Cheap (the knife itself goes for about 8USD)
- Large solid blade with long edge
- Simple construction (not much that can go wrong)
Cons
- Blade itself runs at 1 USD /piece
- Blades are only available in specialized shops (larger arts and crafts stores).
« Last Edit: May 26, 2015, 11:48:27 PM by Etherealicer »
us Offline ToolJoe
Re: Olfa Cutter (Hobby and Crafts knife)
Reply #1 on: May 27, 2015, 03:53:11 PM
They have those in the US. They call them Exacto Knives.
Reply #2 on: May 27, 2015, 05:10:02 PM
You mean X-acto knives?
There is a ton of brands like these, however all of them have relatively thin blades like scalpels or thin break-off blades.
This one here is a beast with a thick and stiff blade. I think that is what makes it interesting.
Reply #3 on: May 27, 2015, 08:15:54 PM
« Last Edit: May 27, 2015, 08:18:37 PM by SteveC »
us Offline Neko2
  • I have too many and not enough.
Reply #4 on: June 04, 2015, 03:20:40 AM
Olfa is to X-acto what Spyderco is to SOG.
Might look similar but one of them pays a lot more attention to quality.
I have a couple Olfa snap off cutters  (the stainless steel ones) and they are like tiny lasers.
fr Offline m47mu74nt
Reply #5 on: August 03, 2023, 08:52:11 PM
Let's bump that old thread with some OLFA Goldie's : here are mine
What about yours?
