jlwatso1's 31 Day SOG Super Power Badge Quest
jlwatso1 · 111 · 10877
us Offline jlwatso1
Re: jlwatso1's 31 Day SOG Super Power Badge Quest
Reply #60 on: January 16, 2016, 09:49:51 PM
Day 16
Enjoyed getting to read to my daughter while she drank her Orange juice this morning. Then got Powerlocked and loaded to go to Home Depot.
« Last Edit: January 16, 2016, 09:54:48 PM by jlwatso1 »
us Offline jlwatso1
Reply #61 on: January 16, 2016, 09:54:12 PM
Did a handle upgrade to a table my wife's parents gave us. Used the flathead. Took a couple before and after pics.
Reply #62 on: January 16, 2016, 10:23:11 PM
Don't let me stop you.  You're very lucky to still have that fingertip.
Remember, pain is temporary, glory is everlasting, and chicks dig scars.
I know that's for sure glad I didn't lose the tip. Cool quote. :tu: Is it an original?
One of the reenactment groups I used to belong to had a sub-group that performed live steel (both impromptu and choreographed) sword fighting demonstrations, living chess games, melees, and battle reenactments.  The fighters took great care to practice safety measures, but broken fingers and lacerations were common, even with blunted blades.  They had the saying printed on T shirts, but they had it in Latin.
Dolor transit Gloria aeterna est Pullos fodere cicatrices
It sounds better in Latin, but everything usually does.
us Offline jlwatso1
Reply #63 on: January 16, 2016, 10:27:07 PM
That's pretty cool. Thanks for sharing!
us Offline jlwatso1
Reply #64 on: January 18, 2016, 05:37:11 AM
DAY 17
Not much to report today. Just did a little Powerlock pocket carry to church.
us Offline jlwatso1
Reply #65 on: January 18, 2016, 01:35:37 PM
DAY 18
Used the Powerlock to pull an ingrown hair! That's some tweezer like persition! Hopefully Deadmun gets a little more use than this today, just thought I would share this pic at the moment. :D
us Offline jlwatso1
Reply #66 on: January 19, 2016, 03:30:40 AM
Did a change out on the air to water VRF and installed an air to air VRF for testing. Wired in high voltage and com. Use wire strippers as well, just didn't have a chance to take a pic of the strippers in use. Here's a few action shots. Wiring high voltage, tightening static taps. Last few were cutting Armaflex to cover 1 5/8", 1 1/8", 5/8", and 3/8" copper.
us Offline jlwatso1
Reply #67 on: January 19, 2016, 10:38:25 PM
DAY 19
Off day, just ran errands today. Picked up a key chain tape measure and had to use the knife on the PL to open it. Then cleaned up the garage some while my little girl took her nap. Used the knife again to break down some boxes to have the recycle company pick up tomorrow.
us Offline jlwatso1
Reply #68 on: January 20, 2016, 03:10:23 AM
Changed the water filter in the fridge. Needed a little help from my Powerlock.
us Offline jlwatso1
Reply #69 on: January 21, 2016, 02:14:39 AM
DAY 20
Pork tenderloin with Tuscan seasoning from Costco! :drool:
us Offline jlwatso1
Reply #70 on: January 22, 2016, 04:44:44 AM
DAY 21
PL didn't see a whole lot of action today. Just used it to change socks for wet bulb readings and work on some static taps. My spring came in for the 1/4 driver the other day. I haven't put it on yet because I want to put some heat shrink on it like I saw a thread for on here the other day.
us Offline jlwatso1
Reply #71 on: January 23, 2016, 05:33:25 AM
DAY 22
Used my Powerlocks to strip and crimp connections on a new ground wire to replace one with the insulation burned off. Later I used the pliers as an ice pick. I was trying to cool down some recovery tanks for some R-410a to keep the pressure down where it wouldn't trip the high pressure control on the recovery machine. Recovered about 125 lbs.
us Offline jlwatso1
Reply #72 on: January 24, 2016, 05:28:05 AM
DAY 23
Didn't do a whole lot today. Thought I would snap a picture of the EDC tools that the Powerlock has been riding around with in my pouch. Next picture is the rest of my EDC. Not pictured is my i-phone 6s. Had to use it to take the pictures.
us Offline jlwatso1
Reply #73 on: January 25, 2016, 05:49:05 AM
DAY 24
Put myreplacement Spring on my Powerlock today. Used some heat shrink to hold it on as seen in another thread.
se Offline Fortytwo
Reply #74 on: January 25, 2016, 11:29:37 AM
DAY 24
How does it fold now? Seems to me like the tubing would be in the way for the adjacent tools? Considering doing the same before I lose the spring.
us Offline jlwatso1
Reply #75 on: January 25, 2016, 11:47:32 AM
DAY 24
Mine catches on the screwdriver just a little bit more when I deploy the 1/4" drive, but it seems like all the tools do that any way... You should try it, worst case- you cut it off if you don't like it. Took me a couple trys for the heat shrink not to break. Don't apply too much heat and make sure you have a clean edge- no nicks.
us Offline jlwatso1
Reply #76 on: January 26, 2016, 05:16:08 AM
DAY 25
Not a whole lot of action for the Powerlock today. Just tightening some static taps. Here's a beauty shot on my drill press.
Reply #77 on: January 26, 2016, 07:48:33 AM
It looks like that drill press was made back when the Kraken was a guppy.  You can't beat old tools when they work, but just try to track down a part when they don't.  :rant::facepalm:
us Offline jlwatso1
Reply #78 on: January 26, 2016, 01:59:34 PM
It was my grandpa's. My parents still have his old lathe and machinist's drill press back home in Oklahoma. I hope to add them to my collection as well. I enjoy getting to work on things with his tools. Brings back memories of him.
us Offline sLaughterMed
Reply #79 on: January 26, 2016, 02:41:01 PM
That is a really cool heirloom.
Laughter is the best Medicine
us Offline jlwatso1
Reply #80 on: January 27, 2016, 05:05:52 AM
Day 26
Off day today. No action for the Powerlock. Just pocket carried. Here's a pic of the Powerlock posing for the camera.
us Offline rdub934
Reply #81 on: January 28, 2016, 04:33:43 AM
Day 26
Full splits with both covers off. Sexy, but still classy! :rofl:
us Offline jlwatso1
Reply #82 on: January 28, 2016, 05:35:41 AM
DAY 27
Just change socks for the wet bulb readings on the room this morning. Just a bunch of screen watching on another VRF. Wall mout units this time 6 in each of the two rooms. Got the 100% (80/67-95), 75%(80/67-81.5), 50% 80/67-68), and 25% (80/67-65) cooling tests completed and set the room for high temp heating (70/<60- 47/43) before ending my shift. Hopefully night shift will be able to get it out along with SCHE [Simultaneous Cooling and Heating (Outdoor room set to Heating conditions 47/43), one indoor room set to Cooling 80/67 and the other indoor room set to heating conditions 70/<60.] , and then low temp heating 17/15 outdoor. I'm sure that was TMI but thought I would go into a little more detail if anyone was interested. Here's anther beauty shot.
us Offline jlwatso1
Reply #83 on: January 29, 2016, 05:26:10 AM
DAY 28
Got to work and the tests were complete. Wasn't feeling too good, but chose to stick it out the rest of the day. Used my Powerlock Pliers to grip and remove a screw that had the Philips head stripped out after breaking off the long threads sticking through the plywood wall.(Sorry no pics of that.) Managed to pinch a blood blister on my hand on the next one I tried and had to resort to the sawzaw. Then used them to smash the ends of some copper lines before putting some tape on them to keep trash out. Lastly, I used the knife to cot some Armaflex while insulating copper for the next setup.
Reply #84 on: January 29, 2016, 05:13:46 PM
Gnarly
us Offline jlwatso1
Reply #85 on: January 30, 2016, 04:40:54 AM
DAY 29
Worked on a VRF setup we started on yesterday. Used my Powerlock to woller out copper after using the tubing cutters. Thought I would share a few pictures.
Offline Idahoreferman
Reply #86 on: January 30, 2016, 04:49:53 AM
What are you working on?
us Offline jlwatso1
Reply #87 on: January 30, 2016, 05:00:12 AM
It is a VRF (Variable Refrigerant Flow) Heatpump system we are setting up in a Psycrometric Chamber. We test other HVAC systems as well. This one is a 24 ton with 3 Outdoor units and 12 indoor units (6 in each indoor room).
us Offline jlwatso1
Reply #88 on: January 31, 2016, 05:02:14 AM
DAY 30
Powerlock just got some pocket time today. Here's a beauty shot.
Reply #89 on: February 01, 2016, 02:28:52 AM
Sorry mate but it does have to be from Mr Pinchy.   :kirky:
